You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2656) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.6.0 (2656) English
Posted by: pspad | Date: 03/29/2015 11:06 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2655)
News
XML converter - new user highlighter + Code explorer (Michael Seume )
New option ForceSaveWork=0/1 (Program settings / Direct edit) will save open and recent files after each change instead of program close
Code explorer for Java Script - fixed default alphabetical sort
AutoComplete - fixed writing with accented chars
Fixed save file to OEM with semigraphic
#2 Re: PSPad unicode 4.6.0 (2656) English
Posted by: Freeman | Date: 03/29/2015 14:30 | IP: IP Logged
Yeah! Great! You also forgot about 4-byte UTF-8 and surrogate pairs, they also work fine!
#3 Re: PSPad unicode 4.6.0 (2656) English
Posted by: pash | Date: 03/31/2015 08:51 | IP: IP Logged
German Umlaute (äöü ...) are broken, they are displayed as a box.
Edited 1 time(s). Last edit at 03/31/2015 08:51 by pash.
#4 Re: PSPad unicode 4.6.0 (2656) English
Posted by: pspad | Date: 03/31/2015 09:00 | IP: IP Logged
pash:
Where are broken?
#5 Re: PSPad unicode 4.6.0 (2656) English
Posted by: pash | Date: 03/31/2015 09:26 | IP: IP Logged
In the normal editor view, the file was saved as ansi. opend in pspad460b2653 without a problem and in pspad460b2656 the umlaut is broken.
#6 Re: PSPad unicode 4.6.0 (2656) English
Posted by: pspad | Date: 03/31/2015 09:52 | IP: IP Logged
Can you send me any your file to support mail?
Can you check regional settings / last tab / System administration if there is German for non unicode applications?
#7 Re: PSPad unicode 4.6.0 (2656) English
Posted by: pash | Date: 03/31/2015 10:30 | IP: IP Logged
Ok, mail send and the regional settings for non unicode programms is German (Germany).
#8 Re: PSPad unicode 4.6.0 (2656) English
Posted by: m2u_germany | Date: 03/31/2015 11:43 | IP: IP Logged
Similar problem here, occured on German system with a file that contained a longer dash (Alt + 0150).
#9 Re: PSPad unicode 4.6.0 (2656) English
Posted by: Freeman | Date: 03/31/2015 11:50 | IP: IP Logged
pash:
It can be some PSPad cache issue. I got Russian character lost for auto-load files, running this build first time. Close/open file has solved this problem.
#10 Re: PSPad unicode 4.6.0 (2656) English
Posted by: toralf | Date: 04/01/2015 16:43 | IP: IP Logged
The field for "Documentary comments" in Highlighter Setting only allows 2 characters. Is that correct?
