You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.6 (2426) English
Posted by: Andreas | Date: 10/31/2011 17:01 | IP: IP Logged
Ok for me on WIN XP with 7z
Posted by: molinarm | Date: 10/31/2011 18:01 | IP: IP Logged
Is it just me or did flags actually disappear from the Setting window where you select the language?
Mario
Posted by: pspad | Date: 10/31/2011 20:18 | IP: IP Logged
molinarm:Is it just me or did flags actually disappear from the Setting window where you select the language?
Mario
This build is update only. You must replace existing full version, not delete previous...
Posted by: Skulstad | Date: 11/01/2011 10:47 | IP: IP Logged
pspad:Skulstad:There is an archive file inside the zip, but it has no extension. When I extracted this file, and added a zip extension, it is all ok. May this be the solution?what do you mean? I checked content of archive and I didn't find any archive inside pspad456b2423.zip without extension
Well, that is what I found in the download file, and I have no further explanations.
Regards,
Jorn Chr. Skulstad
Posted by: Skulstad | Date: 11/01/2011 12:24 | IP: IP Logged
I'm talking about version 2426, not 2423.
Regards,
Jorn Chr. Skulstad
Edited 1 time(s). Last edit at 11/01/2011 12:24 by Skulstad.
Posted by: smoon177 | Date: 11/04/2011 09:59 | IP: IP Logged
I'm a HTML developer. When I use the find & replace feature, I really wish to be able to do it in multi-line. Bcause, my replacing text is often very long with many lines. How to do this in PSPad? Please think about that. Thanks!
Posted by: cebe | Date: 11/04/2011 16:45 | IP: IP Logged
There's always a lot of HTML 4 & 5 elements which doesn't show the closing tag : fieldset, video, audio, button, aside, hgroup, menu...
Thanks
Posted by: francheu | Date: 11/04/2011 21:01 | IP: IP Logged
smoon177:I really wish to be able to do it in multi-line.
Use the phreplace extension. You can find it here: www.pspad.com
François
Posted by: pspad | Date: 11/04/2011 22:44 | IP: IP Logged
cebe:Hi,There's always a lot of HTML 4 & 5 elements which doesn't show the closing tag : fieldset, video, audio, button, aside, hgroup, menu...
Thanks
1. Only elements what has sence are marked as pair. Each added element slow down page drawing.
2. I am not web programmer. If you want to help, example of elements doesn't help me. I need list of missing tags
Posted by: BudMan | Date: 11/06/2011 15:17 | IP: IP Logged
WinZIP 16.0 Pro cannot open this file. I have downloaded it several times with the same error. In addition, the lick to the "change log" does not work.
