You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2386) English
Goto Page: 1 2 3 4 5 Next
#1 PSPad unicode 4.5.5 (2386) English
Posted by: pspad | Date: 03/14/2010 12:57 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
Changes to 4.5.5 (2385)
News
Search/replace in files now works with R/O files too
In Highlighter settings / HTML is possible to activate/deactivate template support
Added File Remove/Delete on the background detection
Fixes
Remove additional spaces with active WordWrap
JScript - escaped comment problem
FTP client - fixed problem with slow SSL/TLS communication
#2 Re: PSPad unicode 4.5.5 (2386) English
Posted by: Lolo | Date: 03/15/2010 11:46 | IP: IP Logged
Thanks for this new version !
Just one thing. It seems that "File change detection" is still broken.
If I open a text file in PSPad and Notepad in the same time and modify and save it in Notepad, PSPad does not detect the file modification.
I have done the test at the root of my hard drive C:
Could you confirm this behavior?
Thanks and have a nice day.
Lolo
EDIT:
Strange.
I have change put in [Special settings] to CheckDocChanges to 0 and restore it to 1 and now it works.
I don't know why I have had this "bug"
I hope it will continue to work fine.
Sorry for the inconvenience.
Edited 1 time(s). Last edit at 03/15/2010 11:51 by Lolo.
#3 Re: PSPad unicode 4.5.5 (2386) English
Posted by: stefangabos | Date: 03/16/2010 10:18 | IP: IP Logged
zen coding has now been released for PsPad! but only now i realize that i don't see the "Scripts" menu anymore. how can i enable it? why did it dissappear? thank you
update: sorry, i found it! smiling smiley integrated scripting support, i know, i know smiling smiley
Edited 1 time(s). Last edit at 03/16/2010 10:45 by stefangabos.
#4 Re: PSPad unicode 4.5.5 (2386) English
Posted by: fetis | Date: 03/19/2010 01:08 | IP: IP Logged
Shit. JavaScript regression. Comments at the beginning of a line
stop working.
I wouldn't recommend this build for JS developers
#5 Re: PSPad unicode 4.5.5 (2386) English
Posted by: BloodSword | Date: 03/19/2010 21:21 | IP: IP Logged
Oh yes, that's the case... Hmm but it is not such a bug that I will return to the previous version. I can wait till it is fixed.
#6 Re: PSPad unicode 4.5.5 (2386) English
Posted by: stefangabos | Date: 03/19/2010 23:27 | IP: IP Logged
can we pretty please have the "trim trailing spaces" be a 3-state option so that we can also have it work *only* when saving a file?
also, is there a way for changing the colors of symbols showing spaces, tabs & line-ends? this is of no real importance of course, i'm just curios smiling smiley
thanks!
Edited 1 time(s). Last edit at 03/19/2010 23:33 by stefangabos.
#7 %File% bug
Posted by: fetis | Date: 03/22/2010 14:45 | IP: IP Logged
I suppose this's bug (not only for current build, but for previous too).
I set some external programs for .html files, path looks like this
"C:\blah\blah\firefox.exe" -new-tab "%File%"
But when I have selected text and call this external program (either via hotkey, or menu) PSPad opens me a temp file with selected text inside.
I think it's a bug since we have a special macro for selected text %SelText%.
P.S. Submited this in the tracker pspad.nlift.com
Edited 2 time(s). Last edit at 03/22/2010 15:08 by fetis.
#8 Re: %File% bug
Posted by: pspad | Date: 03/22/2010 18:56 | IP: IP Logged
fetis:
Answer for you: pspad.nlift.com
Edited 1 time(s). Last edit at 03/22/2010 18:57 by pspad.
#9 Re: PsPad bug
Posted by: holger | Date: 03/24/2010 08:21 | IP: IP Logged
Windows XP SP3, processor: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz 2120 MHz, 2046MB RAM
Kurze Fehlerbeschreibung: (Zusammenfassung)
Folgende Schritte führen zum Fehler:
1)erstelle eine Datei (create File)
2)lade die Datei in PsPad (load in PsPad)
3)editiere die Datei mit Notepad & speichere (Edit with Notepad and save)
Result:
Warnung
File content change check - file not found! Deleted?
W:\wrk\CheckAbt.p
OK
instead of Refresh-Dialog.
Please fix as soon as possible.
Greetings Holger
PS: Solution found! PSPadShell.dll wasn't properly registered.
Edited 3 time(s). Last edit at 03/24/2010 09:01 by holger.
#10 Re: %File% bug
Posted by: ferry | Date: 03/24/2010 19:20 | IP: IP Logged
"In the favorite panel, you can set any count of compilers you need."
I cannot find this panel. Not in "Project settings", nor in "Highlighter settings".
Where is it, please?
