You are here: PSPad forum > Developer forum > PSPad unicode 4.5.5 (2374) English
Posted by: pspad | Date: 11/08/2009 23:19 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.5 (2373)
News
Manifest file was moved out of PSPad.exe. In default is set "asInvoker"
Posted by: F170 | Date: 11/09/2009 02:39 | IP: IP Logged
great
Posted by: Thralia | Date: 11/09/2009 09:31 | IP: IP Logged
Thanks for the autoindent update, it's very convenient.
Though, I think it broke the undo feature a bit ; here's an example :
pspad_undo_scrn1.jpg : before any modification to the file
pspad_undo_scrn2.jpg : I press enter at the end of a line. The following one gets autoindented as expected (thanks again ^^)
pspad_undo_scrn3.jpg : upon ctrl-z, instead of merely deleting the line I just created, it deletes the line with the indentation + (level of indentation + 1) caracters of the following line (to confirm, I gave it a few tries and it always acted the same).
I hope my english is not too bad and this will be able to help you ...
Posted by: Billy | Date: 11/09/2009 11:08 | IP: IP Logged
Now Visual Themes are broken in Win7. They work in XP though...
Posted by: pspad | Date: 11/09/2009 11:19 | IP: IP Logged
Billy:Now Visual Themes are broken in Win7. They work in XP though...
What you mean? There is standalone manifest file now, you can remove/rename it to prevent PSpad to use themes
Posted by: Billy | Date: 11/09/2009 11:24 | IP: IP Logged
pspad:Billy:Now Visual Themes are broken in Win7. They work in XP though...What you mean? There is standalone manifest file now, you can remove/rename it to prevent PSpad to use themes
I mean that controls like buttons, checkboxes etc. are not themed anymore. The included .manifest file works in XP but it doesn't work in Win7.
Edit: I took other .manifest files and renamed them to PSPad.exe.manifest and still no luck. This method usually works to make apps theme-aware but not with PSPad.
Edited 1 time(s). Last edit at 11/09/2009 11:38 by Billy.
Posted by: fetis | Date: 11/09/2009 11:54 | IP: IP Logged
Thank you for JavaScript highlighter fix
Posted by: Whitewater | Date: 11/09/2009 13:09 | IP: IP Logged
Thralia:Thanks for the autoindent update, it's very convenient.Though, I think it broke the undo feature a bit ; here's an example :
pspad_undo_scrn3.jpg : upon ctrl-z, instead of merely deleting the line I just created, it deletes the line with the indentation + (level of indentation + 1) caracters of the following line (to confirm, I gave it a few tries and it always acted the same).I hope my english is not too bad and this will be able to help you ...
I can confirm this. This is serious, since it can really destroy your code if you don't double-check everything after pressing CTRL+Z.
Posted by: programmer9 | Date: 11/09/2009 13:19 | IP: IP Logged
Brilliant - the C/C++ bracket highlighting works again, many thanks for your excellent program.
Posted by: hamasaki | Date: 11/09/2009 20:19 | IP: IP Logged
Yes, I can confirm the undo isn`t working properly. Once again, I`m reverting back to the previous version.
Editor PSPad - freeware editor, © 2001 - 2010 Jan Fiala
