You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2374) English
#21 Re: PSPad unicode 4.5.5 (2374) English
Posted by: MrSpock | Date: 2009-11-16 22:19 | IP: IP Logged
ad 1. I think there is a script that can update the project folder from a real folder on disk.
#22 Re: PSPad unicode 4.5.5 (2374) English
Posted by: BloodSword | Date: 2009-11-17 12:19 | IP: IP Logged
I know, but I think it should be user's choice if the project tree is virtual or not. This would make some thinks much easier.
#23 Re: PSPad unicode 4.5.5 (2374) English
I tested this script and it does not work for me... Using Vista SP2 HE.
#24 Re: PSPad unicode 4.5.5 (2374) English
Posted by: bobbydj | Date: 2009-11-24 11:39 | IP: IP Logged
Can you add a split on the edited file to have 2 different views on this file.
That compares 2 parts of codes.
Thanks in advance.
#25 Re: PSPad unicode 4.5.5 (2374) English
Posted by: pspad | Date: 2009-11-24 12:03 | IP: IP Logged
bobbydj:
Thanks in advance.
Right mouse on active tab and split horizontally/vertically
#26 Re: PSPad unicode 4.5.5 (2374) English
Posted by: qyqcheerup | Date: 2009-11-28 10:07 | IP: IP Logged
It's great! Thank you!smiling smiley
#27 Re: PSPad unicode 4.5.5 (2374) English
Posted by: Inzabi | Date: 2009-12-14 13:36 | IP: IP Logged
problem with syntax highlighting in "HTML multihighlighter" mode
Edited 1 time(s). Last edit at 2009-12-14 13:40 by Inzabi.
#28 Re: PSPad unicode 4.5.5 (2374) English
Posted by: c3k | Date: 2009-12-14 15:50 | IP: IP Logged
undo bug confirmed
i suggest to use 2357 because with the current one can lose part of code because of the newline-undo bug and 2357 is the last without indent bug
#29 Re: PSPad unicode 4.5.5 (2374) English
Posted by: Vany | Date: 2009-12-14 16:31 | IP: IP Logged
Inzabi: if you are not inside <?php ... ?> no syntax is used, no comment, that's OK. If you are inside a comment, it's hilighted OK until the ending php tag ?> is found, thats correct, ?> has higher priority than */.
#30 Re: PSPad unicode 4.5.5 (2374) English
Posted by: carbonize | Date: 2009-12-14 16:39 | IP: IP Logged
Inzabi:
If you'd bothered to use the search function you would see this is a common problem when using multihighlighting and is remedied by switching to PHP highlighting.
Carbonize
