You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2349) English
Goto Page: 1 2 3 4 Next
#1 PSPad unicode 4.5.4 (2349) English
Posted by: pspad | Date: 2009-04-13 15:13 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.4 (2346)
News
MS SQL highlighter - dblclick selects @ char as part of variable
PAS highlighter - possibility to set color for data types
Code Explorer is focused after synchronize with code button (in case if Set cursor after goto is disabled)
Code explorer - item stays highlighted (not greyed) even Code explorer isn't focused
Code explorer - added support for ABB Rapid (ftABB file type). Set it as file type in user highlighter definition
Statusbar - diskette symol is active with same functionality as Save button
Lorem Ipsum form remebers last setting over PSpad sessions
Maximum unnumbered bookmarks stored in project file was extended to 100 for each file
Included the current TiDy.exe version from 03/2009
Corrections
programm writes registry key PSPadPath each start - it's necessary for Windows explorer context menu
PHP highlighter corrections
#2 Re: PSPad unicode 4.5.4 (2349) English
Posted by: papi | Date: 2009-04-16 00:21 | IP: IP Logged
Corrections
I did not try this new build yet, because of the quoted part. I am in doubt: Does it write into the registry also when I use a portable installation?
Thx!
P.
#3 Re: PSPad unicode 4.5.4 (2349) English
Posted by: pspad | Date: 2009-04-16 04:25 | IP: IP Logged
PSPad writes into this key in all version from the begin (in your previous version too).
There are 3 entries.
#4 Re: PSPad unicode 4.5.4 (2349) English
Posted by: Mario | Date: 2009-04-16 07:10 | IP: IP Logged
Why is writing the EXE file path to the registry necessary for the ShellExtension? The PSPadShell.dll is located in the same directory as the EXE itself. You can just assume that both files are at the same location and thus avoid writing to the registry making PSPad "more" portable smiling smiley
#5 Re: PSPad unicode 4.5.4 (2349) English
Posted by: pspad | Date: 2009-04-16 09:08 | IP: IP Logged
You can have shell extension in other folder
PSPadPath is used for Notepad replacement too - it need to know where PSPad is.
#6 Re: PSPad unicode 4.5.4 (2349) English
Posted by: Mario | Date: 2009-04-16 09:49 | IP: IP Logged
That makes sense, of course smiling smiley
Can you comment on this visual bug I reported for the previous build 2346?
Furthermore, is there any chance that the word-wrap bugs get fixed?
#7 Re: PSPad unicode 4.5.4 (2349) English
Posted by: Lolo | Date: 2009-04-20 10:37 | IP: IP Logged
Hello Jan,
There is a new bug introduced in this version when saving a new file.
Here is the way to reproduce it :
- Open PSPad and create a new file:
- Type some characters and press Ctrl+S to save
- Now the file is saved but the small red tick on the Tab is still present.
This bug does not exists in v4.5.4 build 2346
I hope you could fix it in the next release.
Thanks and have a nice day.
Lolo.
#8 Re: PSPad unicode 4.5.4 (2349) English
Posted by: pspad | Date: 2009-04-21 05:42 | IP: IP Logged
Thank you for info. I found a problem and fixed it.
#9 Re: PSPad unicode 4.5.4 (2349) English
Posted by: tobias1985 | Date: 2009-04-21 13:15 | IP: IP Logged
Is there a chance to see a expand/collapse-functionality in a next version?
I think this is a main-feature for an editor for programmers.
#10 Re: PSPad unicode 4.5.4 (2349) English
Posted by: hankejh | Date: 2009-04-21 13:36 | IP: IP Logged
No.
Please try this forum's search feature before posting. You'll find no shortage of discussion on code folding.
