You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2346) English
#11 Re: PSPad unicode 4.5.4 (2346) English
Posted by: pspad | Date: 2009-03-02 10:39 | IP: IP Logged
human:
Cobol syntax work fine for me, although there are some missing elements. I really like to help and update the syntax to the current COBOL 2008 draft, but I didn't found the syntax scheme. Where can I modify it?
If it's some way hard coded, can you please mail the according parts to me?
human
KeyWords:
3d
accept
access
acquire
action
action-copy
action-current-page
action-cut
action-delete
action-first-page
action-hide-drag
action-last-page
action-next
action-next-page
action-paste
action-previous
action-previous-page
action-undo
add
address
adjustable-columns
advancing
after
alignment
all
allowing
alphabet
alphabetic
alphabetic-lower
alphabetic-upper
alphanumeric
alphanumeric-edited
also
alter
alternate
and
any
apply
are
area
areas
area-value
arithmetic
ascending
assign
at
author
auto
auto-decimal
automatic
auto-skip
auto-spin
background-color
background-colour
backward
b-and
bar
beep
before
beginning
bell
b-exor
binary
bit
bitmap
bitmap-end
bitmap-frame
bitmap-handle
bitmap-load
bitmap-number
bitmap-start
bitmap-timer
bitmap-trailing
bitmap-width
bits
blank
b-less
blink
block
b-not
boolean
b-or
bottom
box
boxed
browser
busy
buttons
by
calendar-font
call
cancel
cancel-button
case
cd
cell
cell-color
cell-data
cell-font
cell-protection
cells
center
centered
centered-headings
century-date
cf
class
clear-selection
clock-units
close
cobol
code
code-set
col
collating
color
colors
column
column-color
column-dividers
column-font
column-headings
column-protection
combo-box
comma
command-line
commit
commitment
common
communication
comp
comp-0
comp-1
comp-2
comp-3
comp-4
comp-5
comp-6
comp-7
comp-8
comp-9
computational
computational-0
computational-1
computational-2
computational-3
computational-4
computational-5
computational-6
computational-7
computational-8
computational-9
computational-x
compute
comp-x
com-reg
configuration
connect
console
contained
contains
content
continue
control-area
controls
converting
copy-selection
corr
corresponding
count
crt
crt-under
currency
current
cursor
cursor-col
cursor-color
cursor-frame-width
cursor-row
cursor-x
cursor-y
custom-print-template
cycle
dashed
data
data-columns
date
date-compiled
date-entry
date-written
davf-hhmmss
davf-hhmmsshh
davf-yymmdd
davf-yyyymmdd
davf-yyyymmddhhmmsshh
day
day-of-week
db
db-access-control-key
dbcs
db-data-name
db-exception
db-format-name
db-record-name
db-set-name
db-status
dd
de
debug-contents
debugging
debug-item
debug-line
debug-name
debug-sub-1
debug-sub-2
debug-sub-3
decimal-point
declaratives
default
default-button
delimited
delimiter
depending
descending
destination
destroy
detail
disable
disconnect
disk
display
display-1
display-2
display-3
display-4
display-5
display-6
display-7
display-8
display-9
display-columns
display-format
divide
divider-color
dividers
division
dot-dash
dotted
down
drag-color
drop
drop-down
drop-list
duplicate
duplicates
dynamic
egcs
egi
else
emi
empty
empty-check
enable
enabled
end
end-accept
end-add
end-call
end-compute
end-delete
end-disable
end-divide
end-enable
end-evaluate
end-exec
end-if
endif
ending
end-multiply
end-of-page
end-perform
end-read
end-receive
end-return
end-rewrite
end-search
end-send
end-start
end-string
end-subtract
end-transceive
end-unstring
end-write
engraved
ensure-visible
enter
entry
entry-field
entry-reason
environment
eop
equal
equals
erase
error
escape
escape-button
esi
evaluate
event
event-action-fail
event-type
every
exact
exceeds
exception
exception-value
excess-3
exclusive
exec
execute
exhibit
exit
exit-pushed
expand
extend
external
externally-described-key
fd
fetch
file
file-control
file-id
file-name
file-pos
fill-color
fill-color2
filler
fill-percent
final
find
finish
finish-reason
first
fixed
flat
flat-buttons
floating
font
footing
for
foreground-color
foreground-colour
form
format
frame
framed
free
from
full
full-height
function
generate
get
giving
global
go
goback
go-back
goforward
go-forward
gohome
go-home
gosearch
go-search
graphical
grdsrch-found
grdsrch-not-found
grdsrch-wrapped
greater
grid
grid-searchall
grid-searchcolumn
grid-searchforwards
grid-searchhidden
grid-searchignore
grid-searchmatch
grid-searchmoves
grid-searchskip
grid-searchvisible
grid-searchwrap
grip
group
group-value
handle
has-childen
heading
heading-color
heading-divider-color
heading-font
headings
heavy
height
hidden-data
high
high-color
highlight
horizontal
hot-track
hscroll
hscroll-pos
ch
chain
chaining
changed
character
characters
check-box
checked
id
identification
if
in
include
index
index-1
index-2
index-3
index-4
index-5
index-6
index-7
index-8
index-9
indexed
indic
indicate
indicator
indicators
initial
initialize
initiate
input
input-output
inquire
insertion-index
insert-rows
inspect
installation
into
invalid
i-o
i-o-control
is
item
item-text
item-to-add
item-to-delete
item-to-empty
item-value
japanese
jcllib
job
just
justified
kanji
keep
kept
key
keyboard
label-offset
last
last-row
ld
leading
leading-shift
left
left-justify
left-text
length
length-check
less
like
limit
limits
linage
linage-counter
line
line-counter
lines
lines-at-root
link
linkage
list-box
locally
lock
long-date
low-color
lower
lowered
manual
mass-update
max-lines
max-text
max-val
max-value
member
memory
menu
merge
message
methods
min-val
min-value
mixed
mode
modified
modify
modless
modules
more-labels
move
msg-begin-entry
multiline
multiple
multiply
multline
name
native
navigate
negative
next
next-item
nextpage
no
no-auto-default
no-autosel
no-box
no-dividers
no-echo
no-f4
no-focus
no-group-tab
no-key-letter
none
normal
no-search
not
no-tab
notify
notify-dblclick
notify-change
notify-selchange
no-updown
number
num-col-headings
num-columns
numeric
numeric-edited
num-rows
object-computer
occurs
of
off
ok-button
omitted
on
only
open
optional
or
order
organization
other
output
overflow
owner
packed-decimal
padding
page
page-counter
paged
paged-at-end
paged-at-start
paged-empty
page-setup
page-size
palette
panel-index
panel-style
panel-text
panel-widht
paragraph
password
pend
perform
pf
ph
pic
pixels
placement
pl-sort-default
pl-sort-native
pl-sort-native-ignore-case
pl-sort-none
plus
pointer
pop-up
position
position-shift
positive
present
previous
print
printer
printer-1
printing
print-no-prompt
print-preview
print-switch
prior
proc
procedure
procedures
proceed
process
processing
program
program-id
prompt
properties
protected
purge
push-button
query-index
queue
radio-button
raised
random
range
rd
read
read-only
realm
receive
reconnect
record
record-data
recording
record-name
records
record-to-add
record-to-delete
redefines
reel
reference
references
refresh
region-color
relation
relative
release
remainder
removal
renames
repeated
replacing
report
reporting
reports
required
rerun
reserve
reset-grid
reset-list
reset-tabs
resource
retaining
retrieval
return
return-code
reversed
reverse-video
rewind
rewrite
rf
rh
right
right-align
right-justify
right-text
rimmed
rollback
rolling
rounded
row-color
row-color-pattern
row-dividers
row-font
row-headings
row-protection
run
same
save-as
save-as-no-prompt
screen
scroll
scroll-bar
sd
search
search-options
search-text
section
secure
security
segment
segment-limit
select
select-all
selection-index
selection-text
self-act
send
sentence
separate
separation
separator
sequence
sequential
session-id
set
shading
shared
shift-in
shift-out
short-date
show-lines
show-none
show-sel-always
sign
singleline
size
solid
sort
sort-control
sort-core-size
sort-file-size
sort-merge
sort-message
sort-mode-size
sort-order
sort-return
source
source-computer
space-fill
special-names
spinner
square
standard
standard-1
standard-2
standard-3
standard-4
start
starting
start-x
start-y
static
static-list
status
status-bar
stop
stop-browser
store
string
subfile
subprogram
sub-queue-1
sub-queue-2
sub-queue-3
sub-schema
subtract
sum
suppress
switch
switch-1
switch-2
switch-3
switch-4
switch-5
switch-6
switch-7
switch-8
symbolic
sync
synchronized
system
tab
table
tabs
tab-to-add
tab-to-delete
tally
tallying
tape
tenant
terminal
terminate
termination
termination-value
test
text
than
then
thread
through
thru
thumb-position
tiled-headings
time
timeout
times
title-bar
title-position
to
top
track-thumb
trailing
trailing-shift
trailing-sign
transaction
transceive
transparent
transparent-color
tree-view
tvni-first-visible
tvni-child
tvni-next
tvni-next-visible
tvni-parent
tvni-previous
tvni-previous-visible
tvni-root
tvplace-first
tvplace-last
tvplace-sort
type
underline
unequal
unframed
unit
unlock
unsorted
unstring
until
up
update
upon
upper
usage
usage-mode
user
use-return
use-tab
using
valid
validate
value
value-default
value-format
value-multiple
value-picture
values
value-variable
variable
varying
vertical
very-heavy
virtual-width
visible
vpadding
vscroll
vscroll-bar
vscrool-pos
vtop
wait
when
when-compiled
width
window
with
within
words
working-storage
wrap
write
write-only
zero-fill
PreprocessorWords
basis, cbl, control, copy, delete, eject, insert, ready, reload,
replace, reset, service, skip1, skip2, skip3, title, trace, use
StringWords
high-value, high-values, low-value, low-values, null, nulls, quote,
quotes, space, spaces, zero, zeroes, zeros
AmbigiousWords
label
please send me list of the missong words for section and i will update it
#12 Re: PSPad unicode 4.5.4 (2346) English
Posted by: human | Date: 2009-03-02 13:45 | IP: IP Logged
Hi Jan!
This list doesn't distinguish between the different standards and manufacturer specific extensions.
I've attached three lists (did you receive them or should I post them here?):
reserved85.txt - These can be used for almost every manufacturer.
reserved85to2008.txt - All words in the newer standards that didn't occur in the 85er standard (2008 standard is still a draft and may change)
acu.txt - All words not in 85 or newer standards that are specific to and mainly working only with ACUCOBOL. (A lot of these are included in the version of 2346). If it's possible at least the manufacturer specific should have another colour.
I doesn't know of any of the PreprocessorWords from your list. Where are they from?
A lot of cobol words have their ending pairs (if end-if; evaluate end-evaluate; display end-display; ...) it seems only if end end-if are marked as belonging together. Can you change this, too?
What should the Context/COBOL.DEF do? It seems to be broken to me.
These two files types are often used as a cobol copy (same like a #include in C++), maybe you want to add them to the "standard file extensions" for Cobol scheme: copy cpy.
The last point - Preprocessors:
There are a lot of preprocessors for different things in COBOL available. One of the most things are SQL-Preprocessors, but the syntax between them differ a lot. There are other preprocessors for company specific things.
These could and should not be implemented into the standard COBOL syntax scheme but it would be useful if one could add them. I think of something like a multi level syntax scheme: Use the COBOL one shipped with PSPad, define another one for the preprocessor(s) in use and enable them both at one time.
Is this possible someway or could be implemented?
Greetings,
human
Edited 1 time(s). Last edit at 2009-03-02 13:49 by human.
#13 Re: PSPad unicode 4.5.4 (2346) English
Posted by: c3k | Date: 2009-03-05 12:11 | IP: IP Logged
°digit°:
c3k:
The new PHP highlighter don't select the full var name when doubleclicking on it!!! Now the name is selected but not the dollar character, why?
I need it for some macros, is possible to put it back?
Hi c3k,
I've had a similar probem while usinge the language 'AutoHotkey'. After a distressed night searching for a solution I found this workaound:
(Thread with my related question) -> forum.pspad.com
... maybe this will show u a direction ... hope so ;)
thx for your attention!
i'm happy you solved
i've try your suggestion in the other thread (thank you), but didn't work for me
i've added the $ char in "Frantovo_PHP.INI" in "Syntax" dir, but nothing change
besides no dollar here until now and it always selected with the rest of the word...
i hope Jan or someone else can give me some documentation or confirm me that is a bug
#14 Re: PSPad unicode 4.5.4 (2346) English
Posted by: human | Date: 2009-03-05 12:27 | IP: IP Logged
Hi Jan!
Did you received the lists? If not, should I post them here?
There are two other things I recognized recently:
- Debug lines (D in column 7) are grayed out like comments. They appear not italic, this is fine. Could you make them appear a little bit darker (dark grey)?
- All entries appear in the code explorer, even if they are commented out. Could you filter the divisions/sections that are only comments?
human
#15 Re: PSPad unicode 4.5.4 (2346) English
Posted by: pspad | Date: 2009-03-06 09:54 | IP: IP Logged
human:
Hi Jan!
human
No, I have no mail with lists from you.
Highlighter settings / Cobol / Color tab. Set debug lines with style you need.
#16 Re: PSPad unicode 4.5.4 (2346) English
Posted by: human | Date: 2009-03-06 10:32 | IP: IP Logged
Debug lines highlighting works fine, thank you!
I've just send the three lists to you via PM.
The other open COBOL points:
1. All entries appear in the code explorer, even if they are commented out. Could you filter the divisions/sections that are only comments?
2. I doesn't know of any of the PreprocessorWords from your list. Where are they from?
3. A lot of COBOL words have their ending pairs (if end-if; evaluate end-evaluate; display end-display; ...) it seems only if end end-if are marked as belonging together. Can you change this, too?
4. What should the Context/COBOL.DEF do? It seems to be broken to me.
5. These two files types are often used as a COBOL copy (same like a #include in C++), maybe you want to add them to the "standard file extensions" for Cobol scheme: copy cpy (I've done this manually).
6. The last point - Preprocessors:
These could not and should not be implemented into the standard COBOL syntax scheme but it would be useful if one could manually add them. I think of something like a multi level syntax scheme: Use the COBOL one shipped with PSPad, define another one for the preprocessor(s) in use and enable them both at one time.
Is this possible with recent PSPad in some way or could this be implemented?
human
#17 Re: PSPad unicode 4.5.4 (2346) English
Posted by: Lupo | Date: 2009-03-12 09:09 | IP: IP Logged
Jan, I found a small bug in the code explorer when using C:
Sequence A:
if (any condition) { /* 2-line comment
starting on same line as the if statement */
Sequence B:
/* 2- line comment starting on
next line */
Sequence A seems to irritate the code explorer. After that sequence, while-, if- and for-statements are shown in the explorer, as if they would be functions. however, if there is a newline between the opening bracket and the comment (like in sequence B), it works correctly. I guess, that the opening bracket { is not counted for the level counter in sequence A.
Edited 1 time(s). Last edit at 2009-03-12 09:25 by Lupo.
#18 Re: PSPad unicode 4.5.4 (2346) English
Posted by: krishan | Date: 2009-03-20 11:04 | IP: IP Logged
Hi Jan,
it seems, that the editor handling of PHP variables is broken with this build. In older versions, if I double clicked on a variable it got marked completely with the "$" at the beginning. Now it is marked without the "$". Did you change anything on the code?
Best regards,
Krishan
#19 Re: PSPad unicode 4.5.4 (2346) English
Posted by: carbonize | Date: 2009-03-20 11:59 | IP: IP Logged
krishan:
Hi Jan,
Best regards,
Krishan
Already been reported and Jan has already said it is fixed in the next build he just hasn't released it yet.
Carbonize
#20 Re: PSPad unicode 4.5.4 (2346) English
Posted by: Mario | Date: 2009-03-25 10:30 | IP: IP Logged
When you maximize PSPad in Vista/Server 2008, you can still see the right border of the maximized child window inside. This doesn't happen with XP/2003. Can this be fixed?
Here's a screenshot:
Edited 2 time(s). Last edit at 2009-03-25 11:00 by Mario.
