You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.3 (2243) English
Posted by: pspad | Date: 2006-11-02 20:29 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB) updated 11/3/2006 18:05 SEC
Changes to 4.5.2 (2241)
News
** as new line comment User highlighter style
Corrections
ruller update and zooming font with mouse wheel
highlight matching pairs on the first line
Java Code explorer
script function reloadFile()
CSS Code explorer and IDs list
switch windows and different shortcut then Ctrl+Tab assigned
missed test dialog after start
Edited 4 time(s). Last edit at 2006-11-03 17:07 by pspad.
Posted by: jgodfrey | Date: 2006-11-03 01:50 | IP: IP Logged
Jan,
As always, thanks for the new build. Can you please tell me if the "search wrap" issue mentioned at --> forum.pspad.com is a bug, or if it's being controlled by a new (and unknown to me) option since build 2239?
Thanks for any insight.
Jeff
Posted by: Daniel | Date: 2006-11-03 04:46 | IP: IP Logged
Thanks for the great editor and the new udpate.
I have a suggestion on supporting UTF-8 with and without BOM. Is it possible to add another Code page type in the "Format" menu just like the 2 UTF-16 types "UTF-16 LE" and "UTF-16 BE" so you now have "UTF-8" and "UTF-8 BOM". You can then remove the obscure "indent.bytes in UTF-8 coding" option in the "Program behaviour" section of "Program Settings".
Posted by: pspad | Date: 2006-11-03 05:23 | IP: IP Logged
Search replace needs to be completly rewrited.
Posted by: Pierre.Brico | Date: 2006-11-03 07:17 | IP: IP Logged
Hi Jan,
Thanks for each new build you do !
In this build you forget to remove a debug message which appears when in the Windows Explorer you click on a file to edit it
Regards,
Pierre
Posted by: tylyseppo | Date: 2006-11-03 08:20 | IP: IP Logged
Thanks for the great program.
There is an extra message in this build, though. When opening a file from Explorer menu and PSPad is already open, shows a message box "C:\Program files\PSPad\PsPad.Exe" "X:\path\file".
Edited 1 time(s). Last edit at 2006-11-03 08:20 by tylyseppo.
Posted by: pspad | Date: 2006-11-03 08:24 | IP: IP Logged
Yes, I will remove it tonight
Posted by: Jon | Date: 2006-11-03 09:51 | IP: IP Logged
The problem with window switching via keyboard shortcuts seems to be fixed. (There is still the already mentioned cosmetic problem that Next Window is missing in the Window menu. NBD as I don't use this menu.)
Thanks for fixing this... was really driving me nuts.
Posted by: jgodfrey | Date: 2006-11-03 12:34 | IP: IP Logged
pspad:Search replace needs to be completly rewrited.
Jan,
Assuming the above response was to me regarding my "search wrap" issue... Is it possible to correct just the wrapping issue (which has only been broken since 2239) without completely rewriting the search/replace functions?
Thanks,
Jeff
Posted by: Anders | Date: 2006-11-03 15:17 | IP: IP Logged
Quote:** as new User highlighter style
What does that mean? Any example of usage?
