You are here: PSPad forum > Developer forum - new builds > PSPad 4.5.0 (2177) English
Posted by: tdusem | Date: 2006-01-17 14:46 | IP: IP Logged
No preference on format. whatever is easier for you.
Posted by: tdusem | Date: 2006-01-17 14:56 | IP: IP Logged
I like the whole file diff in the text diff function.
Bug in text diff:
The file line numbers don't display when the diff is first displayed. as line scroll on they are numbered.
Posted by: carbonize | Date: 2006-01-17 16:31 | IP: IP Logged
I'd say stick with .cab or switch to .zip as these both have support on all Operating Systems. Switching to .7z would force a lot of users to download additional software and could put some users off. Possibly not that much of a problem if it's only the betas you compress this way. I have winrar installed which extracts .7z files so not a problem here. You could use the 7-Zip self extractor format if needs be I suppose then there would be no need for the software to be installed.
Carbonize
Posted by: Gerzo | Date: 2006-01-17 19:20 | IP: IP Logged
pspad wrote:
> Question
> Some users suggested to use the 7Zip format instead the CAB
> format for the beta version packages. Do you want to change the
> beta version package format ?
I'm fine with both, but if I had to, I'd vote for 7Zip.
(I go with Triplex's comment about PSPad/7Zip vs. Notepad/Cab here, also 7Zip saves about 100kb on Filesize with this Beta ;) )
> in the Program settings/Program added option [x]Highlight URL
> addresses
Ah, great Idea - since I'm one of those people who use a black background, I find the default dark blue for highlightet URLs a bit too dark on those rare occasions where I open files without an assigned colorscheme (there's no setting for this color, is there ?).
Oh, and thanks for PSPad, it's my favourite text editor !
Posted by: Lolo | Date: 2006-01-18 09:30 | IP: IP Logged
First of all, thanks a lot for this new version.
I have a strange behavior. When I open an x86 Assembly file, PSPad does not highlight the syntax while it works perfectly with other file type like ASP or Visual Basic.
The "Show / Hide syntax" button of the toolbar is not checked.
If I click on "Change document syntax highlight" PSPad recognize that the file is a x86 assembly file. Now if I click on Cancel button, PSPad highlight the syntax and the "Show / Hide syntax" button is checked.
Is it a bug?
Thanks and have a nice day.
Posted by: pspad | Date: 2006-01-18 20:26 | IP: IP Logged
There is limit to auto highlight file.
Program settings / Direct edit
change value of HLUpToSize variable e.g. to 1000000 (bytes)
Posted by: boots | Date: 2006-01-18 20:38 | IP: IP Logged
> I prefer 7zip, it is one of the best Free & Open Source
> Software with high compression ratio, support both Windows and
> Linux (but PSPad not run in Linux :( )
PSPad works for me under Wine
Posted by: Lolo | Date: 2006-01-19 08:44 | IP: IP Logged
You are right!
Posted by: stefang | Date: 2006-01-19 11:30 | IP: IP Logged
cab is ok
Posted by: Patrick | Date: 2006-01-19 14:16 | IP: IP Logged
Thank you very very much for your great job.
I've made many people happy around me thanks to you tool.
We mainly use it for LOG analysis (string search, highlight, ..) and working on files of about 30MB and use also sometimes for editing (XML, ...)
I've been using 4.3.3 (2085) and was quite happy.
The update to version 4.5.0 make me quite disappointed from a speed of view:
- opening a 30M test file is quick
- applying text color takes about 13-14 secondes on 4.3 and 4.5 release
- BUT search a string (with line list) takes less than 1 second with 4.3 and .... several minutes in 4.5 (we can see the cursor moving from top to down).
So, for me, the update is unfortunaly not interesting .
What such difference ???
Hello from France
