You are here: PSPad forum > Developer forum - new builds > PSPad 4.5.0 (2177) English
Posted by: Triplex | Date: 2006-01-16 23:09 | IP: IP Logged
The size is not really the point. Try 7Zip on other types of data. The difference might be wider. There is no easy user interface to create a CAB (like right click CAB into ..., UnCAB to ...).
It is not a problem at all for me to receive PSPad update under CAB or any exotic format. Jan uses what he sees fit. I guess The PSPad cab is generated by a tool, if this tool can also add an installer on top of the cab then this would be the end of the story.
But because the decompression of the cab is manual so another format that can create an auto-extractible archive seems to be more convenient.
Posted by: pspad | Date: 2006-01-17 04:57 | IP: IP Logged
You can use any compression soft to unpack CAB with right click.
You are right, I am using tool to generate CAB. If somobody want, I can write tool to pack/unpack CAB with the right mouse click.
Posted by: PsychodelEKS | Date: 2006-01-17 07:21 | IP: IP Logged
pspad wrote:
> I want to keep the file icon width.
> The icon must be able to display several states together.
> If you give me better symbols, no problem for me to change it.
> R/O files are marked with the black band
Can you tell what states should be displayed by the icons, may be i'll imagine smth acceptable =) And the preferred size also.
How about the sound event?
Posted by: pspad | Date: 2006-01-17 08:17 | IP: IP Logged
states:
modified
hex editor
R/O
autorefresh
FTP
together and it's combinations
Text difference has own icon.
Posted by: nTE | Date: 2006-01-17 08:38 | IP: IP Logged
I'd like to say thanks for implementing the option [x]Highlight URL addresses. :[b][/b])
As for the archive format I prefer 7zip because of it's compression ratio and because it's widespread.
Posted by: ShiLong | Date: 2006-01-17 10:56 | IP: IP Logged
7z is not interesting in wide range. Jan can reach more people with CAB archives, its the best way. 7z is today a bordergroup software, maybe in one year is 7z redy for wide range use, but tody not! You can unpack the CAB archive, zip it with 7z and place it on your own webserver for all people with 7z packer!
Posted by: Bart | Date: 2006-01-17 11:29 | IP: IP Logged
Thanks for the new version.
Well i would prefer 7Zip too.
There are two great apps for free available that can decompress 7-Zip and a lot of other formats:
7-Zip GUI
www.7-zip.org
* Packing / unpacking: 7z, ZIP, GZIP, BZIP2 and TAR
* Unpacking only: RAR, CAB, ARJ, LZH, CHM, Z, CPIO, RPM and DEB
IZArc
www.izarc.org
7-ZIP, A, ACE, ARC, ARJ, B64, BH, BIN, BZ2, BZA, C2D, CAB, CDI, CPIO, DEB, ENC, GCA, GZ, GZA, HA, IMG, ISO, JAR, LHA, LIB, LZH, MDF, MBF, MIM, NRG, PAK, PDI, PK3, RAR, RPM, TAR, TAZ, TBZ, TGZ, TZ, UUE, WAR, XXE, YZ1, Z, ZIP, ZOO.
Posted by: pspad | Date: 2006-01-17 11:40 | IP: IP Logged
And all freeware or commercial application can unpack the CAB format...
Posted by: jubbbird | Date: 2006-01-17 11:49 | IP: IP Logged
Forgive me if this is not a bug, or if its already been reported:
It seems that if I set bookmarks at specific line numbers in my code, all are stored in the project and succesfully recalled at a later date, except bookmark 1. Bookmark 1 is unset on closing and reloaded PSPad...
Hope this helps, cheers for the great software
Posted by: PsychodelEKS | Date: 2006-01-17 12:21 | IP: IP Logged
pspad wrote:
> states:
> modified
> hex editor
> R/O
> autorefresh
> FTP
Ye, combining those all is a tough question =( More over in such small area...
Microsoft should perish for their tabs controls! ;)
