You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2140) beta English
Posted by: pspad | Date: 2005-11-13 07:00 | IP: IP Logged
I don't understand. This dialog havn't to be show (in normal case) under PSPad main window. This is possible only if you have a "something" what change the standard Window behaviour (e.g. stupid Genius mouse driver)
Posted by: Wacky | Date: 2005-11-14 11:53 | IP: IP Logged
Naughty Muppet wrote:
> When i select the print preview function in this version the
> program crashes for me.
I've got the same problem!
Posted by: Skulstad | Date: 2005-11-14 13:09 | IP: IP Logged
Hi. I reported theis problem a couple of weeks ago, so I guess that Jan will take care of it...
Regards
Posted by: Coditor | Date: 2005-11-14 13:33 | IP: IP Logged
Some time ago I have encountered a (imho) bug but failed to mention it. I have just installed the new build and the bug is still here - I guess you weren't aware of it.
Create a new PHP script and start typing:
<?php
if (isset($_GET{"test"})) {
echo "test = " . $_GET{"test"};
As soon as you type "if (" PsPad will nicely add a closing ")" after the cursor. However, if you then continue typing "isset(" PsPad won't add a second closing ")".
Posted by: pspad | Date: 2005-11-14 16:31 | IP: IP Logged
I have no response from the SynEdit community, so I will return back to the previous editor version (used in 2139)
Posted by: pspad | Date: 2005-11-14 16:34 | IP: IP Logged
There are two modes in the Program settings for the char completion. Go to program settings / Editor-behaviour and uncheck []Smart char completion
Posted by: Jody | Date: 2005-11-14 23:48 | IP: IP Logged
You wrote:
"I have no response from the SynEdit community, so I will return back to the previous editor version (used in 2139)"
Print Preview works fine for me... XP Home SP2
If returning to the previous editor version used in 2139 will you be using a more recent version with word wrap fixed? I sure hope so.
Thanks,
Jody
Posted by: Jume | Date: 2005-11-15 01:18 | IP: IP Logged
i can confirm the print preview problem
it says "printer is not currently printing"
in the preview area appears the header as it is configured, and the number "1:" for the first line (if you have the option for printing lines on), after that, nothing else
however it is not a crash for me, but an "application error", i should press the button "ok" a decent number of times (the error keeps there over and over), and then the print preview closes itself and the program continues to work normally
and heres the info in the case it helps...
Exception class: EPrinter
Exception address: 00439652
Stack list, generated 15/11/2005 2:09:14
[0043964D] Printers.RaiseError + $11
[00439BA6] Printers.TPrinter.CheckPrinting + $2E
[00439934] Printers.TPrinterCanvas.Changing + $8
[004302CB] Graphics.TCanvas.GetHandle + $7
[004C71CD] SynUnicode.TextExtent (Line 2184, "SynUnicode.pas" + 9) + $13
[004C71F3] SynUnicode.TextWidth (Line 2194, "SynUnicode.pas" + 4) + $6
[00581D77] SynEditPrint.TSynEditPrint.ExpandAtWideGlyphs (Line 375, "SynEditPrint.pas" + 8) + $22
[00582BE4] SynEditPrint.TSynEditPrint.TextOut (Line 750, "SynEditPrint.pas" + 9) + $9
[00582FB1] SynEditPrint.TSynEditPrint.WriteLine (Line 863, "SynEditPrint.pas" + 10) + $6
[00583136] SynEditPrint.TSynEditPrint.PrintPage (Line 894, "SynEditPrint.pas" + 22) + $12
[005CF420] SynEditPrintPreview.TSynEditPrintPreview.Paint (Line 404, "SynEditPrintPreview.pas" + 28) + $1C
[00583237] SynEditPrint.TSynEditPrint.PrintToCanvas (Line 929, "SynEditPrint.pas" + 3) + $2
[005CF437] SynEditPrintPreview.TSynEditPrintPreview.Paint (Line 407, "SynEditPrintPreview.pas" + 31) + $12
[004A6003] Controls.TCustomControl.PaintWindow + $57
[004A1F02] Controls.TWinControl.PaintHandler + $4E
[004A23CF] Controls.TWinControl.WMPaint + $3F
[00489838] Forms.TCustomForm.WMPaint + $2C
[004A5F9C] Controls.TCustomControl.WMPaint + $10
[0049ED0C] Controls.TControl.WndProc + $188
[004EEDC6] SynEdit.GetMsgProc (Line 10728, "SynEdit.pas" + 26) + $C
[004A1D6B] Controls.TWinControl.WndProc + $157
[0042211C] Classes.TThreadList.UnlockList + $4
[004A19E8] Controls.TWinControl.MainWndProc + $2C
[0042C1C0] Classes.StdWndProc + $14
[0048E2C7] Forms.TApplication.ProcessMessage + $83
[0048E2FE] Forms.TApplication.HandleMessage + $A
[0048ADB9] Forms.TCustomForm.ShowModal + $15D
[0066FE65] uMain.TfPSPad.aPrintPrevExecute (Line 5251, "uMain.pas" + 15) + $4
[0067DDD4] uMain.TfPSPad.ActionListExecute (Line 10584, "uMain.pas" + 8) + $7
[00481BD4] ActnList.TCustomActionList.ExecuteAction + $14
[0048181C] ActnList.TContainedAction.Execute + $14
[004824DB] ActnList.TCustomAction.Execute + $4F
[0042B3DF] Classes.TBasicActionLink.Execute + $13
[004953DB] Menus.TMenuItem.Click + $8F
[004965CB] Menus.TMenu.DispatchCommand + $13
[00489B77] Forms.TCustomForm.WMCommand + $1F
[00487BD5] Forms.TCustomForm.WndProc + $421
[0048E52E] Forms.TApplication.Run + $96
[0069F432] PSPad.PSPad (Line 60, "I:\Delphi7\Projekty\PSPad\PSPad.dpr" + 35) + $7
Program : D:\Programas\Edicion\PsPad\PSPad.exe 4.5.0 (2140)
System : Windows XP Professional, Version: 5.1, Build: A28, ""
Processor: AMD, AMD Athlon(tm) XP 1700+, 1466 MHz MMX
Display : 1600x1200 pixels, 32 bpp
Active Controls Hierarchy:
TButton "bExitIt"
TToolBar "tbPrintPrev"
TfPrintPrev "fPrintPrev"
Posted by: Jume | Date: 2005-11-15 01:24 | IP: IP Logged
more about the printing thingy, i did some additional tests
1.- the number of times the error keeps popping up is not dependant on the number of lines or anything else, but for some kind of timer, if you press the enter button to keep "pressing" the button "ok" as fast as windows can, it will eventually closes (i couldnt close it with mouse clicks for +200 clicks but with the enter key it closed in about a second of trying)
2.- the most important, with syntax highlighting turned off the printing preview works fine, if people can confirm this, maybe theres the problem...
hth
Posted by: Skulstad | Date: 2005-11-15 06:25 | IP: IP Logged
I can confirm issue 2
