You are here: PSPad forum > Translation > Danish by MicCo
Danish by MicCo
#1 Danish by MicCo
Posted by: MicCo | Date: 02/22/2011 09:22 | IP: IP Logged
Hi to all translators smiling smiley
I´m new to this forum, but have been using the PSPad editor for quite some years now, and have been updating the danish.ini, language file, for my owne use. But now I´m thinking about makeing it accesable for all users, including in time, the spell file.
To make sure that I release the right version, as is 4.5.5 (2412), the one I use for now, I need to know if there are any other .INI file that is the most upto-date then the english.ini file ?, as it´s that one I have been using in the past, to make sure that I did the correct update of my danish.ini file.... Please inform me!!
Best regards,
MicCo
(I'm the translator of the Danish language file, if You find any error, please contact me.)
Edited 1 time(s). Last edit at 04/19/2017 11:44 by pspad.
#2 Re: Danish.ini for ver. 4.5.5
Posted by: pspad | Date: 02/22/2011 09:39 | IP: IP Logged
Use Danish.INI from latest build
Search for ;;Translate comments
Translate strings under this comment and remove comment
Send me back the INI file.
I am updating all localizations files with every new build.
#3 Re: Danish.ini for ver. 4.5.5
Posted by: MicCo | Date: 02/22/2011 10:18 | IP: IP Logged
Thanks, I´m on it then smiling smiley
Best regards,
MicCo
#4 Re: Danish by MicCo
Posted by: MicCo | Date: 04/19/2017 12:46 | IP: IP Logged
PSPad danish lang-file for ver. 4.6.2 (2750) are sendt to support.
The file can be downloaded @ www.micco.dk
Best regards,
MicCo
#5 Re: Danish by MicCo
Posted by: MicCo | Date: 04/19/2017 15:43 | IP: IP Logged
PSPad danish lang-file for ver. 5 are sendt to support.
Best regards,
MicCo
