You are here: PSPad forum > Bug report / Hlášení chyb > Re: pspad damaged files?
Posted by: Macari | Date: 2015-10-19 19:05 | IP: IP Logged
First, this happen very rare, but you can say minimum one time each month (I find it), so I think. So I want report it here, but I can't reproduce it.
I use pspad daily (I love it) and since windows 8.1 I catch a strange problem with pspad. See here: www2.pic-upload.de
I use windows 8.1 64 bit with pspad 4.6.0 (2671). I update often pspad and this happen long time in previous versions too. I have no problems with windows 8.1. No crashes, no damaged ssd, all run fine.
The error in file is always the same. This error happen this time in a file with that I work the last 2 days (only with pspad!).
Any clue?
Posted by: pspad | Date: 2015-10-19 19:20 | IP: IP Logged
Update to latest build.
Can you send me some damaged files to support mail?
Posted by: Macari | Date: 2015-10-20 10:34 | IP: IP Logged
I have delete my version and install the lastest full version with update. When I catch the error again, I will try to send you that file.
Posted by: Macari | Date: 2015-10-30 10:36 | IP: IP Logged
I have the error again, with a fresh install of pspad include update 2703.
I have you send a shrinked version of the error file via email.
Here is the same report:
forum.pspad.com
Edited 1 time(s). Last edit at 2015-10-30 10:38 by Macari.
Posted by: Macari | Date: 2015-11-05 13:51 | IP: IP Logged
I get this failure again. This time in utf8 Javascript file.
Posted by: Macari | Date: 2015-12-16 20:20 | IP: IP Logged
Its happen again. file is damaged with FF000000 directly after save in pspad.
Posted by: Macari | Date: 2015-12-27 13:45 | IP: IP Logged
Only as notice. I get the error again. ^^
Posted by: vbr | Date: 2015-12-27 16:11 | IP: IP Logged
just a wild guess, could this problem be possibly connected with code-clips insertion?
The offending code in the previous picture
forum.pspad.com
looks similar to the default code template to "foreach" in php.
Was this template eventually used prior to saving - resulting in the problems described (and likewise in other observed cases)?
Can you check the template file itself for this clip and the encoding of the clip file?
This might explain the problems in inserting some unwanted data, which an editor shouldn't do automatically or even randomly.
regards,
Posted by: Macari | Date: 2016-03-13 15:19 | IP: IP Logged
Unfortunately, this have nothing todo with foreach.
I found out, that this bug comes not only with save files. I have open a php-file that is few months old (original loaded from github) and have this error too. I closed it and open again and the error was away. So pspad add this error with open files too.
Posted by: Wirek | Date: 2016-07-13 09:38 | IP: IP Logged
I've seen that there are reports on misbehaviour of PSPad editor when it is left open for very long time and the OS is put to "Hibernate" or "Stand by" mode (e.g. forum.pspad.com). Maybe a future build without a memory manager would help you.
