You are here: PSPad forum > English discussion forum > Multi-Search
Posted by: pspad | Date: 2014-10-05 08:49 | IP: IP Logged
If PSPad finds what you want you look for, COPY button will copy the same result into new tab. What is selected by regular expression selected, this is copied. Nothing more, nothing less.
Posted by: pspad | Date: 2014-10-05 08:52 | IP: IP Logged
maki:Sorry but the software sucks.
You are right. Anything sucks if you don't know how to use it, if you don't want to learn anything new. If you will work with chainsaw without knowledges, result will be more fatal for you that wrong regular expression.
Posted by: maki | Date: 2014-10-05 08:53 | IP: IP Logged
I know the regex but the software has limits. Do you understand?
What is the length limit regex (PSPad)?
Limit lenght regex
Limit lines
other limit
Edited 2 time(s). Last edit at 2014-10-05 08:55 by maki.
Posted by: pspad | Date: 2014-10-05 08:59 | IP: IP Logged
Limits? Search string is defined as String, it means length is theoretically limited by Integer variable 2 147 483 647 bytes.
Why do you ask for limits when your regular expression doesn't work?
I told you it several times already.
Each 32bits process is limited by 2GB of RAM. This limits program, it's data e.t.c.
PSpad works internally with text in Unicode - 2 bytes per char.
Add undo buffers e.t.c.
PSPad is programmer editor, it means it is projected to edit source code. Isn't projected to work with hundreds MB length files.
Edited 1 time(s). Last edit at 2014-10-05 09:02 by pspad.
Posted by: maki | Date: 2014-10-05 09:04 | IP: IP Logged
Example:
Search function...length of search string to 2046 characters ???
t should be just some improvements(CORRECT) in Scrypt Based on my Multi-Search..
cmd.exe /q/c (for /F "usebackq delims=" %I in ("files.txt") do for /F "usebackq delims=" %J in ("folders.txt") do dir /a-d/b/s "%~fJ"\%I) > "search results.txt
Edited 2 time(s). Last edit at 2014-10-05 09:08 by maki.
Posted by: pspad | Date: 2014-10-05 09:34 | IP: IP Logged
maki:Example:Search function...length of search string to 2046 characters ???
Ask please MS to modify Edit windows control. If there is limit, it's applied to Edit control, not to PSPad
Posted by: maki | Date: 2014-10-05 09:42 | IP: IP Logged
Ask M$, ask the EP forum, ask ... ask ask .. create a million accounts in various forums ... an already asked but in my case it is impossible.
Answer from support: "There is no such need if he asks for only one member of the new features or unique request"
Posted by: pspad | Date: 2014-10-05 10:07 | IP: IP Logged
Suggest your mutiline search request as new topic with good description to others. Note, they mus be capable to understand it.
If there will be enough users who will find it useful, I will implement it.
For edit control without limit you need to send your request to MS. I can use controls what are offered by Windows.
Posted by: maki | Date: 2014-10-05 10:19 | IP: IP Logged
My English is a bad, creating long and complicated questions in the English-speaking forums, will be associated with a misunderstanding.
I asked for a few Polish-popular forums - but no one to answer to my posts ...
Sorry.
He writes short sentences in English, because
Longer sentence = sentence of nonsense.
Posted by: maki | Date: 2014-10-05 10:53 | IP: IP Logged
Stefan - Do you have something in common with Spain?
