You are here: PSPad forum > English discussion forum > Re: Multi-Search
Posted by: maki | Date: 2014-10-03 13:08 | IP: IP Logged
List_of_text_editors
What tools (NOT ONLY FREEWARE!) For Windows 7 - would be suitable for my needs?
Without the console, Linux, Unix, etc.., And operation on long lists. Where there is no need to use regex and is ready options built into the program?
Editor: Option Import List [Search] and Find all names?? ?
Edited 1 time(s). Last edit at 2014-10-03 13:10 by maki.
Posted by: maki | Date: 2014-10-03 13:21 | IP: IP Logged
Support large text ?
Is it finds multiple names at the same time?
NOT REPLACE Only Search
Similar better tool ? ? ?
Languages: English, German
Software Cost: Free
Edited 2 time(s). Last edit at 2014-10-03 13:27 by maki.
Posted by: pspad | Date: 2014-10-03 15:13 | IP: IP Logged
I think for you will be the best way to learn yourself programming. Then you will be able to write the best tool over the world.
Do you know, why your request are not fulfilled by any existing program? Because your request are totally nonstandard.
If you are only one who came with such request and there is no possibility that such functionality will suit for other users, no developer will add it into complex product.
PSPad offers you scripting capabilities using any languages available for Windows Scripting Host. You can write your search include loading search patterns from list or from existing PSPad window.
Posted by: Stefan | Date: 2014-10-03 16:54 | IP: IP Logged
maki:Oh My God. Patern, Regex, Edit, Search and other... This is a toy for preschooler
Fine. Then it may be the right tool for you, isn't it?
If you want to get the work done, you have to learn how the things work.
Quote:I would like to edit something but many times, quicklyI would like the program to have the option "Load List"
Then you may be at the wrong place here.
Your issue is best done by a script and regex use, or by a specialized tool.
A text editor like PSPad is much to slow for productive workers as you seems to be.
Please see if there (click) is a solution for you.
Edited 1 time(s). Last edit at 2014-10-03 18:11 by Stefan.
Posted by: maki | Date: 2014-10-03 21:16 | IP: IP Logged
Stefan - No comment..
Ps. I do not use stupid-ass search engine google.com
Edited 4 time(s). Last edit at 2014-10-03 21:23 by maki.
Posted by: maki | Date: 2014-10-03 21:38 | IP: IP Logged
Without regex
Without script
Solved. I have used other better editor 100% work.
Find all names 1 second !!!!! superfast!
Edited 1 time(s). Last edit at 2014-10-03 21:42 by maki.
Posted by: Stefan | Date: 2014-10-04 08:03 | IP: IP Logged
maki:Ps. I do not use stupid-ass search engine google.com
Why oh why I guessed that allread?
maki:Without regex
Without scriptSolved. I have used other better editor 100% work.
Such Multi-Lines Search Panel will search for one connected block of lines,
not for each line of a set of independent lines.
But I am glad you solved your issue now yourself.
At last you have found the right tool for you and no longer need that stupid PSPad.
Posted by: maki | Date: 2014-10-04 18:41 | IP: IP Logged
ISSUE 1:
multiline search and <<<<NOT!!!>>>> replace
because does not need replacement
ISSUE 2:
Regex not work
^hHaAp9876_-98Gh\.jpg$
Other Regex
OR
is bad because I find all filename jpg files
Edited 3 time(s). Last edit at 2014-10-04 18:49 by maki.
Posted by: pspad | Date: 2014-10-04 19:19 | IP: IP Logged
maki:ISSUE 1:
So don't use replace. I hope you are able to call find dialog only instead of Find/Replace dialog
maki:ISSUE 2:....\....\hHaAp9876_-98Gh.jpg
Regex not work
It doesn't work, cause you didn't read anything about reg expression. You don't know there are some control (or system) chars. Such chars need to be escaped with '\' char.
Your regular expression doesn't work from 2 reasons:
1. ^hHaAp9876_-98Gh\.jpg$
looks for hHaAp9876_-98Gh from the begin of line, but you have path before the name
2. you need to escape char '-'
Working regular expression can looks like this:
^.*hHaAp9876_\-98Gh\.jpg$
Edited 1 time(s). Last edit at 2014-10-04 19:20 by pspad.
