You are here: PSPad forum > English discussion forum > Scripts Menu missing !!!!
Posted by: psergi | Date: 2012-12-06 14:25 | IP: IP Logged
Hello guys,
I just installed PSPad(last version) on my PC.
I can't see Scripts Menu in the Menu bar.
Why ?
How can I see it ?
I have to activate something in configuration tool ?
Thank you
Posted by: pspad | Date: 2012-12-06 14:31 | IP: IP Logged
Program settings / System
Check script support
Posted by: poeth | Date: 2013-01-23 13:46 | IP: IP Logged
I have the same problem and there is no "system" in the program settings dialog.
Posted by: poeth | Date: 2013-01-23 19:31 | IP: IP Logged
OK, next time I'll get some glasses. Thanks!
But now I have the next problem. When I add a new script to the JS directory (e.g. emmet.js) I'll get the errpr message:
"Support for "JScript" active scripting not found! Install WSH with requested language support."
Edited 1 time(s). Last edit at 2013-01-23 20:18 by poeth.
Posted by: Lycox | Date: 2013-03-27 13:16 | IP: IP Logged
poeth:OK, next time I'll get some glasses. Thanks!But now I have the next problem. When I add a new script to the JS directory (e.g. emmet.js) I'll get the errpr message:
Still having the same error. Neither adding "module_title = 'Emmet';" to the JS helped or enabling WSH via registry in addition worked.
Too bad. I saw a video of Emmet and I was very excited about it's functions. Would be nice to have that natevily in PSPad.
Posted by: pspad | Date: 2013-03-27 14:06 | IP: IP Logged
For me wasn't necessary to do anything and scripting was working on Win7 x64. Maybe some your firm politics disables it.
Posted by: Manfred62 | Date: 2013-03-27 18:09 | IP: IP Logged
Quote:Still having the same error. Neither adding "module_title = 'Emmet';" to the JS helped or enabling WSH via registry in addition worked.
also tried to use 'Emmet', but got the same error message.
See this thread. I'm using Win7 x64 as non-admin. As admin I can use the other scripts. But 'Emmet' still doesn't run...
Also I tried to solve my Win7 problem (admin vs non-admin), but no chance.
@Lycox: maybe zen-coding is an alternative for you
PSPad 4.5.9 (2525)
Posted by: pspad | Date: 2013-03-28 06:05 | IP: IP Logged
The solution is enable local scripting in IE properties. On some machines it was disabled.
Posted by: Lycox | Date: 2013-03-28 06:35 | IP: IP Logged
Nope, that didn't work. I did that but I forgot to write that in my last post.
BTW: I'm on Win7 64bit.
