You are here: PSPad forum > English discussion forum > Updated html, xhtml, css def
Posted by: Manfred62 | Date: 2009-12-24 10:48 | IP: IP Logged
Hi Jan
Under the Link you find my updated files (in a zip):
html.def
xhtml.def
css.def
www.box.net
Best make a diff before. Don't know, if I found all.
In html.def found this:
%popis%=@E Popis obrázku:,,,,"
%pict%=@P Obrázek:,,,,"
%zarovnani%=@C Zarovnání obrázku:,,M," ";L;R;M,
Don't know what...
regards and merry christmas
Manfred
Posted by: pspad | Date: 2009-12-24 10:52 | IP: IP Logged
Thank you. I will update it and I will translate clip files to English
Posted by: Manfred62 | Date: 2010-01-06 17:20 | IP: IP Logged
Hi Jan
Happy new year...
I updated the css and xhtml def-files. Added some functions/selections, ordered the sequences of attributes etc..
Please make a diff before using. You can use the same download link from upper post.
Regards Manfred
Posted by: pspad | Date: 2010-01-06 17:28 | IP: IP Logged
Thank you again
Posted by: Manfred62 | Date: 2010-01-10 12:19 | IP: IP Logged
found something .. in html and xhtml
[noscript | content for browser doesn't supported tag SCRIPT]
<noscript %class% %dir% %id% %lang% %on% %style% %title% %xmllang%>
<!-- alternative to javascript -->§|
</noscript>
missing §|
Files at box.net are updated
regards Manfred
Posted by: Manfred62 | Date: 2010-01-11 15:27 | IP: IP Logged
Hi
Sorry, updated some more.. small improvements.
Same Link above, have fun
Manfred
Posted by: Manfred62 | Date: 2010-02-05 13:30 | IP: IP Logged
Small update (function) in CSS.def. Same link/file above.
regards Manfred
Edited 1 time(s). Last edit at 2010-02-05 13:31 by Manfred62.
Posted by: Manfred62 | Date: 2010-02-06 16:33 | IP: IP Logged
Made some more small updates/corrections in css.def
Same link above
Manfred
Posted by: Manfred62 | Date: 2010-02-10 08:56 | IP: IP Logged
Some small updates in xhtml.def
Please always make a diff before using...
Same link above
regards Manfred
Posted by: Manfred62 | Date: 2010-02-11 21:57 | IP: IP Logged
New function in html- and xhtml.def: adding conditional comments for IE's.
Example:
<!--[if lt IE 7]>
<![endif]-->
regards Manfred
same link at box.net
