You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.1 (817) English
#1 PSPad unicode 5.5.1 (817) English
Posted by: pspad | Date: 2024-12-16 06:01 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
488369f05a89930cc0ae35c3b931564eff061f77 pspad551b817.zip
f11d514a5ff0fb88aab31053d600a9448c5f66d2 pspad551b817x64.zip
Changes to 5.5.1 (815)
News:
New version of TiDy (HTML check and transform)
New version of OpenSSL libraries 3.4
Clipboard monitor - detection of changed clipboard entry
Handled wrong FTP password entry and unsuccessful connection - won't be cached
Other fixes reported by users
Edited 1 time(s). Last edit at 2024-12-17 06:19 by pspad.
#2 Re: PSPad unicode 5.5.1 (817) English
Posted by: Henk | Date: 2024-12-16 19:21 | IP: IP Logged
I have replaced (and checked) all files in the program directory with the files from pspad551b817x64.zip.
Maybe I'm doing something wrong, but the "About..." window in PSPAD shows
5.5.1 (815) 13/10/2024 13:03:38
where it should show (817).
With kind regards,
Henk
#3 Re: PSPad unicode 5.5.1 (817) English
Posted by: mce | Date: 2024-12-16 20:45 | IP: IP Logged
I'm not sure when this changed but highlighting of matching brackets changed at some point, seems to highlight on bracket and on the character right after the bracket, for example if I have this code:
if function(parameter) then do:
/*some code here*/
end.
if I place the cursor on "(" it highlights the corresponding ")", good, but if I go to the right on "p" it still keeps the brackets highlighted, if I got to the left on "n" it doesn't highlight (good), as a result I cannot see where the cursor is, if it's on the bracket or after the bracket to know where I am and how to edit the code.
Same if I am on ")" it highlights corresponding "(" ok, but if I am on the space right after ")" it keeps highlighting which is not good in my opinion.
Thank you,
Cristian
Edited 1 time(s). Last edit at 2024-12-16 20:45 by mce.
#4 Re: PSPad unicode 5.5.1 (817) English
Posted by: pspad | Date: 2024-12-17 06:23 | IP: IP Logged
Henk:
With kind regards,
Henk
You are right. The build info in 64b version was wrong. I recompiled it and uploaded again
#5 Re: PSPad unicode 5.5.1 (817) English
Posted by: tmpad | Date: 2024-12-29 11:45 | IP: IP Logged
Any news on the editor engine replacement or the chinese/strange character problem?
The latter is still the most important problem.
#6 Re: PSPad unicode 5.5.1 (817) English
Posted by: blunzn | Date: 2025-01-07 14:03 | IP: IP Logged
Agree, I would also greatly appreciate feedback regarding the chinese character issue.
One thing I noticed is that if an opened file contains a trailing CRLF (0D0A), it is not displayed. We had a similar issue several builds ago but it was fixed already.
Edited 1 time(s). Last edit at 2025-01-07 14:05 by blunzn.
