You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.5.1 (812) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 5.5.1 (812) English
Posted by: Piotr | Date: 2024-01-24 11:24 | IP: IP Logged
Hi Jan,
I cannot set the width of the Date column to a fixed value.
I can change other columns.
ibb.co
Thank you!
#12 Re: PSPad unicode 5.5.1 (812) English
Posted by: pspad | Date: 2024-01-24 13:25 | IP: IP Logged
Date column in the FTP tab is sizeable, just tested.
But there is max width what in your case cover the time, right? I will fix it.
Edited 1 time(s). Last edit at 2024-01-24 13:26 by pspad.
#13 Re: PSPad unicode 5.5.1 (812) English
Posted by: Piotr | Date: 2024-01-25 17:52 | IP: IP Logged
Thanks!
#14 Re: PSPad unicode 5.5.1 (812) English
Posted by: marjuanm | Date: 2024-02-17 21:43 | IP: IP Logged
Freeman:
This build doesn't restore opened files on next run. Build 790 does (just replaced exe file for the rollback).
Hello, I have downloaded and tried this version, but it actually did not respect the session of my previous version of PSpad, I returned to version 790 which does work without problems.
#15 Re: PSPad unicode 5.5.1 (812) English
Posted by: Henk | Date: 2024-02-20 21:52 | IP: IP Logged
When closing the 64bit version I get an Exception EAccessViolation in module PSPad.exe
sad smiley
#16 Re: PSPad unicode 5.5.1 (812) English
Posted by: pspad | Date: 2024-02-21 03:59 | IP: IP Logged
Use 35 b version please
#17 Re: PSPad unicode 5.5.1 (812) English
Posted by: Henk | Date: 2024-02-23 08:31 | IP: IP Logged
I just have overwritten all files in my current x64 PSP program directory with the files in the 32b ZIP-archive. Maybe not the proper way, but it worked.
Now waiting for a stable x64 developer version winking smiley
#18 Re: PSPad unicode 5.5.1 (812) English
Posted by: pkenewell | Date: 2024-02-23 21:30 | IP: IP Logged
Ravelli:
One of my PHP scripts wasn't working today. Turned out there is a mojibake "ÿ..." in the file. It probably happened during a PSPad crash the other day. I will send you the PHP file via email.
I have experienced the same issue twice with the released (5.0.7) version. If seems to be inserting binary characters into the file somehow.
