You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.5.1 (787) English
Posted by: pspad | Date: 2023-05-21 15:13 | IP: IP Logged
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
061d3203da720b5379a1a1346e08eb027bd81465 pspad551b787.zip
ef7b31823119b06477dc84b58b91455374c4ff41 pspad551b787x64.zip
Changes to 5.5.1 (783)
News:
Analytics communication was changed from HTTP to HTTPS protocol
ChatGPT communication was moved to thread. Waiting for result doesn't block PSPad anymore
FTP - possibility to Save file as in file context menu (right mouse)
Processing language - new user highlighter definition
Processing language is supported as embedded in HTML if assigned
Automatic file save (except new) when PSPad losts focus in Program settings / Backup
ChatGPT - small fixes in escaping of sent text
Open file from internet doesn't use current OpenSSL implementation
Drag/Drop file from PSPad file explorer
TextDifference in program settings stripped quotes for external tool parameters
Bookmarks - draw problem in splitted window
Other fixes reported by users
Posted by: Ravelli | Date: 2023-05-24 16:25 | IP: IP Logged
Ahoy all
I just updated and compared all my settings with my instructions... all fine. And I'm happy to see ChatGPT feedback tells me that my quota is used up (btw: I tried ChatGPT heavily via browser, but don't find it any helpful).
But...
The Code Explorer shows instead of a proper folder name some nonsense. It is an open project with many files. The project had been open during the update process. Here a Screenshot. Want files via email?
Friendly greetings
Rav
p.s.: this checkbox from the forum to send me emails on replies is gone
Posted by: pspad | Date: 2023-05-25 06:21 | IP: IP Logged
ChatGPT via API with free account is overloaded. ChatGPT via OpenAI website works - they need people can try it.
Personally I paid $5 on my account (it will be enough at least for 6 months, maybe longer) and it works without problems.
Posted by: Piotr | Date: 2023-05-29 11:44 | IP: IP Logged
CTRL + double click.
Selecting text between "" and '' doesn't work for me.
And it happened after the last update
Thanks for the help
Posted by: pspad | Date: 2023-05-29 12:17 | IP: IP Logged
Piotr:Hi,CTRL + double click.
And it happened after the last updateThanks for the help
Do you mean this last build? I didn't make any changes in this behavior.
Posted by: Piotr | Date: 2023-05-29 13:42 | IP: IP Logged
I'm surprised because it's an automatic setting, not mine.
Where should I look for the error?
Thank you
Posted by: pspad | Date: 2023-05-29 15:43 | IP: IP Logged
I am trying yo gigire out when the problem appears. In this last build? What version + build fid you use before?
Posted by: Ravelli | Date: 2023-05-29 15:57 | IP: IP Logged
I can confirm what Piotr wrote:
Make a new PHP file, add this line:
echo "test 1 2 3...";
Then try to select the string between "" via CTRL+DoubleLeftClick
In 551b783 it selects the entire string, in 787 only the next word.
Friendly greetings
Posted by: pspad | Date: 2023-05-29 16:52 | IP: IP Logged
I know it isn't work. I try to find which version caused it.
Posted by: Freeman | Date: 2023-06-01 10:56 | IP: IP Logged
$url = $base_url.$target_url;
I have a line like above. I want to delete spaces to a particular position on the left (manual unindent). Caret is set to a space. When I press Ctrl+Del, PSPad deletes spaces on the right plus $url. It makes Ctrl+Del totally unusable.
I've tried HTML Multihighlighter and PHP Highlighter (this code is in PHP). Nothing changed. I don't know are there any settings can affect this behavior. This bug exists in build 783 too.
