You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (715) English
Posted by: pspad | Date: 2021-11-28 14:20 | IP: IP Logged
Download links:
SHA1 hash:
641bd510746f72a79e23b5ea4ecc754889585b62 pspad507b715.zip
ba07909837817272008fe219b1da9df9d61726d8 pspad507b715x64.zip
Changes to 5.0.7 (710)
News:
Program settings / Direct edit button (Special settings) - added new option UseClearType = 0/1, what allows you to disable cleartype in the editor window. The settings take effect when the program is restarted
FTP - possibility to set default FTP connection. Put asterisk on the end of FTP connection name.
Clipboard monitor
Fixed behavior of commands Delete last word (Ctrl+BkSpace) and Delete word (Ctrl+Del)
System icons in FTP (if enabled in Program Settings)
Other fixes reported by users
Posted by: pspad | Date: 2021-11-28 14:22 | IP: IP Logged
Do you think this build can be published as new full version, even there is no skin support?
Posted by: jlenfers | Date: 2021-11-29 13:28 | IP: IP Logged
I don't remember, but I think Ctrl+Del should delete only spaces (blank chars) first, instead of spaces + word.
Posted by: pspad | Date: 2021-11-29 13:37 | IP: IP Logged
The behavior now is same like Delphi IDE
Posted by: Gabriel_ACE | Date: 2021-11-29 15:23 | IP: IP Logged
mmmm If I be you, I wait a litle more
Best regards
Posted by: pspad | Date: 2021-11-29 17:29 | IP: IP Logged
Gabriel_ACE:mmmm If I be you, I wait a litle moreBest regards
Problem is I get lot of mails each days wiht reports from 5.0.6.
Posted by: Gabriel_ACE | Date: 2021-11-29 17:51 | IP: IP Logged
ahh ok, I did not know that
in thats case, do it.
You have to discontinue the other program
Posted by: qastrox | Date: 2021-12-02 20:20 | IP: IP Logged
Hi all
Maybe somebody already reported this issue:
This version of PSPad adds a line at the end of file when saving it, even with option "Add CR+LF to EOF" disabled.
Please, my you check?
Thanks
Nicola
Posted by: pspad | Date: 2021-12-02 20:31 | IP: IP Logged
yes, it was reported already.
Posted by: tmpad | Date: 2021-12-03 08:26 | IP: IP Logged
In a previous post you said you "get lot of mails each days", here you say it was "reported already".
What is your preferred way of receiving bug reports and wouldn't a public bug report system make things easier?
