You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (689) English
#1 PSPad unicode 5.0.7 (689) English
Posted by: pspad | Date: 2021-10-29 20:56 | IP: IP Logged
Download links:
SHA1 hash: 7c5bcc56878a7abb9f0c56434c477da55af10081 pspad507b689.zip df57ed0cf79b69485dcebb74d4466b6eab3bff7d pspad507b689x64.zip
Changes to 5.0.7 (687)
News:
PHP highlighter - added "mixed" type
PHP code completion - added magic constants
Check and automatic fix of the recent.ini file
Ruby - multiline string support
Find in Files - click in result - activate file if file is already open
Find in Files - after double click the line was white font on light gray background
TextDiff window - goto source (dblclick)
Recorded Macro play - reduced problems with clipboard
User highlighter - possibility to save definition witht none string highlight
Other fixes reported by users
Known issues:
Edited 1 time(s). Last edit at 2021-10-31 12:04 by pspad.
#2 Re: PSPad unicode 5.0.7 (689) English
Posted by: Gabriel_ACE | Date: 2021-11-02 17:09 | IP: IP Logged
hi!
new spanish update!
forum.pspad.com
#3 Re: PSPad unicode 5.0.7 (689) English
Posted by: pspad | Date: 2021-11-02 19:15 | IP: IP Logged
Gabriel_ACE:
hi!
new spanish update!
forum.pspad.com
Update is for build 687, but this one is 689
#4 Re: PSPad unicode 5.0.7 (689) English
Posted by: Gabriel_ACE | Date: 2021-11-03 11:44 | IP: IP Logged
I always use pspad developer's file spanish.ini sad smiley
ok, I will do it again
#5 Re: PSPad unicode 5.0.7 (689) English
Posted by: pspad | Date: 2021-11-03 12:38 | IP: IP Logged
Maybe you named it wrong only, but you suggest build 687
#6 Re: PSPad unicode 5.0.7 (689) English
Posted by: Gabriel_ACE | Date: 2021-11-03 16:52 | IP: IP Logged
hello, try again to download the file.
I checked it. and it is the same file that I translated and uploaded to the forum
could you check that?
maybe it was wrong in some previous update
#7 Re: PSPad unicode 5.0.7 (689) English
Posted by: Ravelli | Date: 2021-11-07 11:48 | IP: IP Logged
Got an access violation on closing a PHP file via middle-mouse click on the tab: Screenshot
Will update to 701 now.
