You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (659) English
Posted by: pspad | Date: 2021-06-25 21:35 | IP: IP Logged
Download links:
SHA1 hash:
06c394a711105fd929e8f4df73008881f46986cc pspad507b659.zip
ad1ef8e7219290dce27b188734d29aaebafad12e pspad507b659x64.zip
Changes to 5.0.7 (655)
News:
Active file tab highlight when Tab style is selected
Statusbar icons are high DPI ready and light/dark theme ready
TextDiff drop panel was moved from top right to the top left corner
In Filetab context menu you can open file in new PSPad instance as admin
Copy to clipboard always added HTML format
SmartTabs
Active tab after open file from "outside" of PSPad
Select word with dblclick broke on accented chars
Handled exception when decoding invalid string from BASE64
Filetabs visibility after open project or open session
Drag/Drop text with mouse in column or line mode selection
Other fixes reported by users
Known issues:
Posted by: Ravelli | Date: 2021-06-27 14:14 | IP: IP Logged
Hi Jan,
many thanks for the updated development version. I'm just looking through my previous bug reports. This one which is not fixed yet:
Quote:b) Well, this is a minor issue I noticed in a previous version, but it still exists: Word-wrapping makes nonsense under certain circumstances: Video, Screenshot, Description
Maybe I should add... if you follow the video or description, you will find PSPad showing 2 commas, although you typed in 1 only.
Happy Sunday
Ravelli
Posted by: pspad | Date: 2021-06-28 05:23 | IP: IP Logged
Thank you for report. It's visual bug only, there are no 2 commas in the file.
I will try to find a reason.
Posted by: MadCompie | Date: 2021-06-28 06:34 | IP: IP Logged
For the scripting, "selText" method speed problem, here a function to simulate the issue:
Sub TrimTrailingSpaces
If (editorsCount = 0) Then
Exit Sub
End If
Set editor = newEditor()
editor.assignActiveEditor
myCaretX = editor.caretX()
myCaretY = editor.caretY()
x1 = editor.blockBeginX()
y1 = editor.blockBeginY()
x2 = editor.blockEndX()
y2 = editor.blockEndY()
x1 = 1 'steeds vanaf pos.1
bBlockBegin = editor.setBlockBegin (x1, y1)
bBlockEnd = editor.setBlockEnd (x2, y2)
If (x2 > 1) Then
text = editor.Text()
EOL = ""
If InStr(text, Chr(13)) Then
EOL = EOL & Chr(13)
End If
If InStr(text, Chr(10)) Then
EOL = EOL & Chr(10)
End If
lines = Split(text, EOL)
x2 = Len(lines(y2 - 1)) + 1
End If
text = editor.selText()
EOL = ""
EOL = EOL & Chr(13)
End If
EOL = EOL & Chr(10)
End If
i = -1
For Each line in lines
i = i + 1
lines(i) = RTrim(line)
Next
text = Join(lines, EOL)
editor.selText (text) 'this causes the delay
editor.caretX myCaretX
editor.caretY myCaretY
End Sub
This script simply takes each line and strips the trailing spaces.
To simulate, select some 2000 lines in a text file and apply the script. It will take some half a minute...
Posted by: pspad | Date: 2021-06-28 07:21 | IP: IP Logged
MadCompie:This script simply takes each line and strips the trailing spaces.
Testing with 75kB Java script code. It was executed immediately. I added echo before and after the last seltext and there was no delay.
Maybe something in settings.
How long are lines in your code?
Can you send me your PSpad.ini, I can test it with your settings
400kB AHK file with over 10 000 lines, executed immediatelly as well.
Edited 1 time(s). Last edit at 2021-06-28 07:23 by pspad.
Posted by: MadCompie | Date: 2021-06-28 12:12 | IP: IP Logged
You are right! I also tried this with a 7000 lines js file and indeed, very fast!
I think the problem will be related to it's type: it's a COBOL file.
The COBOL syntax does not like everything after pos 72 ;)
Perhaps this causes the delay?
Posted by: pspad | Date: 2021-06-28 16:38 | IP: IP Logged
MadCompie:Hello,
It was caused by Cobol Code folding.
I can solve it by switching off Code folding before SelText in scripting and return it back after. It will be immediate with Cobol files too.
I need to investigate if I can improve Cobol Code folding.
Posted by: Extranjero | Date: 2021-06-30 09:40 | IP: IP Logged
Randomly inserting rare characters is still an issue, but much less than in previous versions.
Same with access violations: still happen, but less.
Minor observation: the save-button sometimes doesn't change to 'active' aspect on changes realized in the code.
Posted by: Greg | Date: 2021-07-01 21:14 | IP: IP Logged
Hello ! ^^
Good news is the back to previous backup works perfectly fine.
I had to use it when i saw it is impossible to Paste to MS Excel. I didn't test it to another program.
Copy :
Fails Paste to Excel :
What it should have done :
Posted by: PGomersall | Date: 2021-07-01 22:23 | IP: IP Logged
Greg,
It works (copy\paste to Excel - I used what you had in your images) for me in this (659 x64) version.
My text type was set to ANSI and document type was txt. Not sure if these settings have effect.
