You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.6 (577) English
Posted by: Professor Bernd | Date: 2021-03-25 13:38 | IP: IP Logged
First tab is NOT activated after PSPad restart.
Prerequisites: A project (.ppr) is used or the following setting is set:
Settings / Program Settings / Files and Dirs / "Save Work/Desktop:" "All opended files"
Bug Description
When closing PSPad while multiple tabs are open, the next time PSPad is opened, all tabs are restored and the last active tab is reactivated. - But NOT on the first tab.
If the first tab is the active tab when you exit PSPad, the next time you open PSPad, the last tab will be activated.
Posted by: pspad | Date: 2021-03-25 14:02 | IP: IP Logged
This bug was there from the begin.
Found and fixed.
Posted by: Professor Bernd | Date: 2021-03-25 22:00 | IP: IP Logged
Thank you!
Posted by: Professor Bernd | Date: 2021-03-25 22:32 | IP: IP Logged
PSPad IDE Style "Windows 10 SlateGray".
Bug: Scrollbar slider dragged over scroll arrows, scrolls unintentionally and selects text.
- Open a file with so much text that there is a horizontal and a vertical scrollbar.
Horizontal
- Set the caret to the beginning of the first line.
- Grab the horizontal scrollbar slider and drag it to the right until it is above the scroll arrow.
=> It will automatically scroll all the way to the right and all the way down and the text will be selected.
Vertical
- Grab the vertical scrollbar slider and drag it down to above the scroll arrow.
