You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.6 (577) English
Posted by: pspad | Date: 2021-03-21 17:21 | IP: IP Logged
Download links:
SHA1 hash:
51ce1b689d16fb58a78f46276050f905ab11725b pspad506b577.zip
a48edd8c86a897d4549d023fe2f1a4972efd491f pspad506b577x64.zip
Changes to 5.0.6 (571)
News:
Project settings, Highlighter settings / Compiler, Tools settings - added possibility to set log encoding (OEM, ANSI / UTF-8)
First time run localization isn't taken from system, but from user OS localization
Autocomplete includes first bracket - new option in Program settings / Editor 2
New program actions aDOSFormat, aMACFormat, aUNIXFormat. It allows change line ends format in scripting, allows to assign shortcut
Program start toolbar flickering
About program dialog with dark skin closes PSPad
Search broke highlight same occurences
Undo/Redo doesn't refresh editor state
Exception when a large number of files are open when starting the PSPad
Catch tool output from Link panel
Posted by: Alex | Date: 2021-03-23 13:18 | IP: IP Logged
hello Jan, Is there possible way to encrease font-size in ftp files list? Like match font-size from editor would be great
Posted by: pspad | Date: 2021-03-23 13:59 | IP: IP Logged
Font size in FTP list and other program parts depends now of your operating system settings. You should see same size in all other application.
Posted by: Alex | Date: 2021-03-24 06:31 | IP: IP Logged
But I cant change font size in this particular element in windows 8. Only all sise as 125%, and this will affect all programs, and its too much
Posted by: pspad | Date: 2021-03-24 06:56 | IP: IP Logged
Isn't there user settings for DPI? You can increase DPI of 10%.
I can make it in PSPad, but in this case i need to do it in whole interface. It means do it manually in all forms, tune up all controls position. Do it in FTP only isn't systemic. And it means lot of hours
I will look to Windows 8 settings but i need access to any computer.
Edited 1 time(s). Last edit at 2021-03-24 07:01 by pspad.
Posted by: Professor Bernd | Date: 2021-03-24 10:21 | IP: IP Logged
Professor Bernd:Bug is still there:PSPad IDE Style "Windows 10 SlateGray". File Tabs Style: Tabs.
If you have a project with 2 rows of tabs, and you select a tab from the upper row, the row is moved to the lower row. If you close PSPad and restart the project, an exception is thrown.
- When restarting PSPad as described above, 2 exceptions are displayed.
- Every time you move or resize PSPad, an exception is thrown.
If you use "File Tabs Style: Flat Buttons", everything is fine. But the buttons are ugly and take a lot of height away. Can you make nice labels available instead of the buttons? Then the problem with the exceptions would be solved, the tabs would look good, use little height and the rows would not be changed anymore (Windows).
Posted by: pspad | Date: 2021-03-24 10:36 | IP: IP Logged
I found some problems with resizing if skin is used.
I believe next build will be OK.
Posted by: Professor Bernd | Date: 2021-03-24 10:42 | IP: IP Logged
Professor Bernd:PSPad IDE Style "Windows 10 SlateGray". If PSPad is maximized on exit and I restart PSPad, the window is then also maximized (= ok). Then I restore the window to its normal size and minimize it to the taskbar. When I restore it from the taskbar, it is maximized again. - This happens every time: When I restore PSPad from the taskbar, it is maximized.
New insight: The bug occurs when you restore the PSPad window by double-clicking on the title bar, but NOT when restoring with the maximize/restore button.
The bug also occurs, for example, when you perform the following steps to reproduce:
- Start PSPad
- maximize window by clicking on the maximize button
- Restore window with double click on the title bar
- Minimize window in taskbar
- Restore window from taskbar
= Window is maximized, although it was restored.
Also, not all tabs are shown, for example, if you maximize a project then restored and not all tabs fit in 1 row.
This can also be reproduced by opening PSPad, maximizing, opening as many tabs, as just fit in 1 row and then restore.
If you then add or delete 1 tab, 2 rows of tabs are shown.
If you then maximize the window, the 2nd row of tabs remains and is shown empty.
If you then add or delete 1 tab, the 2nd tab row (empty) is removed.
After that the game starts from the beginning.
Posted by: Professor Bernd | Date: 2021-03-24 10:44 | IP: IP Logged
pspad:I found some problems with resizing if skin is used.
I am looking forward to it!
Posted by: pspad | Date: 2021-03-24 10:47 | IP: IP Logged
On weekend as usually.
I will test your cases you described.
