You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.4 (539) English
Posted by: pspad | Date: 2020-12-28 11:14 | IP: IP Logged
Download links (5.7 MB):
SHA1 hash:
SHA1 hash:
bfff0009704b333577f2ef11e9b1f74e434991f9 pspad504b539.zip
4e73e6cdffedbbe03c5e9e3264e8eb5b7d958002 pspad504b539x64.zip
Changes to 5.0.4 (535)
News:
Autocomplete doesn't complete numbers
Highlighter settings - added possibility to open selected user highlighter definition
Code explorer - Sort button has "state". You can switch it on/ff for current Window. Default state cames from Program settings / Tools - Sort code explorer
Code explorer - selected item stays selected after sort change or refresh (if exists)
Windows Shell Script - keywords and parameters
Autohotkey Code Explorer - fixed included classes hierarchy, added properties into Code explorer content
PageSetup dialog was enabled in case of Hexedit too and it's call caused exception
Posted by: tertius | Date: 2020-12-28 15:32 | IP: IP Logged
Many thanks for the updated Autohotkey code explorer. Works good. Classes are now shown correctly.
Small issue still exists.
Function definition like this:
atan2(y, x) {
return dllcall("msvcrt\atan2", "Double", y, "Double", x, "CDECL Double")
still has the opening brace { in code explorer. Methods don't have the opening brace any more, but functions still have.
Edited 1 time(s). Last edit at 2020-12-28 15:33 by tertius.
Posted by: pspad | Date: 2020-12-28 16:43 | IP: IP Logged
I will fix it.
Posted by: tmpad | Date: 2020-12-31 10:07 | IP: IP Logged
Issues with "Highlight all occurences of selected text" active (32 bit version)
1)
Double-click behind the last character of a single word, word becomes selected
Other occurences are not highlighted
2)
Single-click inside a selected single word
Word becomes unselected, other occurences of the word remain highlighted
Posted by: pspad | Date: 2020-12-31 10:44 | IP: IP Logged
tmpad:Issues with "Highlight all occurences of selected text" active (32 bit version)
Thank you for info. It looks like there is missing info about selection change when selection is done by mouse clicking
Posted by: Professor Bernd | Date: 2021-01-27 19:09 | IP: IP Logged
pspad:Changes to 5.0.4 (535)News:
Does not work when you save the file.
Posted by: pspad | Date: 2021-01-28 19:52 | IP: IP Logged
Professor Bernd:pspad:Changes to 5.0.4 (535)News:
Code explorer - selected item stays selected after sort change or refresh (if exists)Does not work when you save the file.
Thank you, fixed. Available in the next build.
Posted by: Professor Bernd | Date: 2021-01-29 02:21 | IP: IP Logged
That was fast. Thank you!
