You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.4 (539) English
#1 PSPad unicode 5.0.4 (539) English
Posted by: pspad | Date: 2020-12-28 11:14 | IP: IP Logged
Download links (5.7 MB):
SHA1 hash: SHA1 hash: bfff0009704b333577f2ef11e9b1f74e434991f9 pspad504b539.zip 4e73e6cdffedbbe03c5e9e3264e8eb5b7d958002 pspad504b539x64.zip
Changes to 5.0.4 (535)
News:
Autocomplete doesn't complete numbers
Highlighter settings - added possibility to open selected user highlighter definition
Code explorer - Sort button has "state". You can switch it on/ff for current Window. Default state cames from Program settings / Tools - Sort code explorer
Code explorer - selected item stays selected after sort change or refresh (if exists)
Windows Shell Script - keywords and parameters
Autohotkey Code Explorer - fixed included classes hierarchy, added properties into Code explorer content
PageSetup dialog was enabled in case of Hexedit too and it's call caused exception
#2 Re: PSPad unicode 5.0.4 (539) English
Posted by: tertius | Date: 2020-12-28 15:32 | IP: IP Logged
Many thanks for the updated Autohotkey code explorer. Works good. Classes are now shown correctly.
Small issue still exists.
Function definition like this:
atan2(y, x) { return dllcall("msvcrt\atan2", "Double", y, "Double", x, "CDECL Double") } still has the opening brace { in code explorer. Methods don't have the opening brace any more, but functions still have.
Edited 1 time(s). Last edit at 2020-12-28 15:33 by tertius.
#3 Re: PSPad unicode 5.0.4 (539) English
Posted by: pspad | Date: 2020-12-28 16:43 | IP: IP Logged
I will fix it.
#4 Re: PSPad unicode 5.0.4 (539) English
Posted by: tmpad | Date: 2020-12-31 10:07 | IP: IP Logged
Issues with "Highlight all occurences of selected text" active (32 bit version)
1)
Double-click behind the last character of a single word, word becomes selected
Other occurences are not highlighted
2)
Single-click inside a selected single word
Word becomes unselected, other occurences of the word remain highlighted
#5 Re: PSPad unicode 5.0.4 (539) English
Posted by: pspad | Date: 2020-12-31 10:44 | IP: IP Logged
tmpad:
Thank you for info. It looks like there is missing info about selection change when selection is done by mouse clicking
#6 Re: PSPad unicode 5.0.4 (539) English
Posted by: Professor Bernd | Date: 2021-01-27 19:09 | IP: IP Logged
News:
Does not work when you save the file. sad smiley
#7 Re: PSPad unicode 5.0.4 (539) English
Posted by: pspad | Date: 2021-01-28 19:52 | IP: IP Logged
Professor Bernd:
News:
Thank you, fixed. Available in the next build.
#8 Re: PSPad unicode 5.0.4 (539) English
Posted by: Professor Bernd | Date: 2021-01-29 02:21 | IP: IP Logged
That was fast. Thank you! smiling smiley
