You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.4 (517) English
Posted by: pspad | Date: 2020-08-05 10:38 | IP: IP Logged
Download links (5.7 MB):
SHA1 hash:
63daeafc1c2463faa0c4ae93ab76f6399d78f7c6 pspad504b517.zip
f52da8791c52a6da6235a6aaef8c6d8536ca0eb4 pspad504b517x64.zip
Changes to 5.0.4 (515)
News:
JavaScript highlighter - added support for Template literals (Template strings) and new JScript highlighter attribute Template for color setting
Current file tab highlight
Search/Replace in files - select directory dialog appears under search window, search dialog was always diaplyed on the top
Windows flicker when maximized PSPad is restored from minimized state
Posted by: Professor Bernd | Date: 2020-08-05 14:52 | IP: IP Logged
Hello. Unfortunately the current tab is not highlighted. My settings:
PSPad.ini
HighlightCurrentFileTab=1
MarkCurrentFileTab=1
Settings Dialog Program-1
File Tabs Style: Tabs
What can I do to highlight the current tab?
Posted by: pspad | Date: 2020-08-05 14:56 | IP: IP Logged
Send me screenshot please.
Posted by: Professor Bernd | Date: 2020-08-05 16:54 | IP: IP Logged
Up to version 5.0.4 (403) beta the current tab was highlighted, but as of version 5.0.4 (407) beta it was no longer highlighted.
Edit: The screenshots are from fresh installations.
Edited 1 time(s). Last edit at 2020-08-05 16:56 by Professor Bernd.
Posted by: pspad | Date: 2020-08-05 17:10 | IP: IP Logged
Are you sure you are looking into correct PSPad.ini?
In the program settings / Backup is clickable link to PSPad folder with ini files.
With your settings the file name should look as on your first pic and current file name should be underlined
Posted by: Professor Bernd | Date: 2020-08-05 17:37 | IP: IP Logged
To be on the safe side, I made another fresh installation with full version 5.0.3 (377). Before I started PSPad I copied a PSPad_MU.ini with MultiUser=0 to it. Then I started PSPad and added tabs.
Then I closed PSPad and copied version 5.0.4 (407) beta over it.
In this fresh installation I did not change any other settings.
PSPad.ini
MarkCurrentFileTab=0
Posted by: Professor Bernd | Date: 2020-08-05 19:14 | IP: IP Logged
An additional thing: If you set MarkCurrentFileTab=1, the name in the tab will be underlined in the skins "Windows" and "Carbon", but not in the skin "SlateGray".
Tested in a not fresh installation.
Edited 2 time(s). Last edit at 2020-08-05 19:23 by Professor Bernd.
Posted by: pspad | Date: 2020-08-06 04:43 | IP: IP Logged
Hello. It's underlined, but with black line. I will fix it.
What is strange the tab isn't marked.
Edited 1 time(s). Last edit at 2020-08-06 06:44 by pspad.
Posted by: pspad | Date: 2020-08-06 08:02 | IP: IP Logged
I found a problem with new empty child open after PSpad start. Child isn't maximized.
It will be fixed in the next build.
Posted by: Professor Bernd | Date: 2020-08-06 16:12 | IP: IP Logged
pspad:What is strange the tab isn't marked.
Highlighting the active tab is a very useful feature. It would be nice if you could fix that.
pspad:It's underlined, but with black line. I will fix it.
Thanks.
pspad:I found a problem with new empty child open after PSpad start. Child isn't maximized.
This is good news! I just noticed that if the child is not maximized, the error jumping via LogParser does not jump far enough, so LogWin hides the error line. Thanks.
