You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.4 (381) English
Posted by: pspad | Date: 2020-02-29 18:07 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.3 (377)
News:
Format block (left/right/center) works in column selection with limitation - text doesn't contain real tabs.
User highlighter extended of Variable attribute with possibility highlight PHP like variables (starting with $)
FTP - added possibility to rename folder with connections. It's possible to use it to join folders too
FTP - connection popup menu is organized into submenus according to folders
Updated color scheme PSPad dark and PSPad light
JSON reformat didn't take indent size from the program settings
Char # was added as word break char for HTML and XHTML highlighter
Program settings / System - some option was unavailable
memory leaks joined with Code explorer
FTP - edit FTP - wrong detection of existing connection
Posted by: Professor Bernd | Date: 2020-03-02 00:29 | IP: IP Logged
Hello Jan, is the "4" in the version number correct?
5.0.4 (381)
In both cases, yes or no, you are welcome to delete my posting.
Bernd.
Posted by: ok1 | Date: 2020-03-02 00:43 | IP: IP Logged
Yes, the version number is 5.0.4 as reported from Help -> About and also the program version number from the .EXE file.
Posted by: pspad | Date: 2020-03-02 02:44 | IP: IP Logged
Yes the number is correct. What's wrong with the number?
Posted by: Professor Bernd | Date: 2020-03-02 09:31 | IP: IP Logged
I see there's nothing wrong with the number. I was wrong. I didn't realize it was a full version. I apologize.
Posted by: pspad | Date: 2020-03-02 09:51 | IP: IP Logged
No problem. Developer builds are something like preview builds for people who wants check new functionality before official build or for people who has some requests - they can confirm that it works as they want.
In the moment the official version is released, version of developer builds is increased.
Edited 2 time(s). Last edit at 2020-03-02 09:51 by pspad.
Posted by: Professor Bernd | Date: 2020-03-02 14:00 | IP: IP Logged
Thanks for the information.
Bernd.
Posted by: MadCompie | Date: 2020-03-02 21:37 | IP: IP Logged
Dear Jan,
I can create a group in FTP and drag a connection into this group.
Opening FTP in "edit mode" works fine, I see the group.
But opening FTP in "popup mode" (clicking the small arrow) results in an "access violation at address 00842039 in module PSPad.exe. Read of address 0000009D"
Log:
Stack list, generated 2/03/2020 21:31:50
[00842039] uFTP.TfFTP.popupConnectionsPopup (Line 695, "uFTP.pas" + 27) + $8
[0040D19C] System.@FinalizeRecord + $28
[006860CB] Vcl.Menus.TPopupMenu.DoPopup + $13
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.4 (381)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 47BA,
Processor: Intel, Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz, 3390 MHz MMX
Active Controls Hierarchy:
TListView "listFTP"
TfFTP "fFTP"
TTabSheet ""
TPageControl "PageExplorer"
TPanel "panelProject"
TfPSPad "fPSPad"
Posted by: tmpad | Date: 2020-03-21 19:28 | IP: IP Logged
The text diff function in the 64bit version is not working at all. This has been reported several times in the past. Is there a chance that it will be fixed soon?
As I rely on that feature, I have to switch back to the 32bit version for the time being.
Posted by: omega7 | Date: 2020-04-17 08:23 | IP: IP Logged
I am experiencing the issues with text diff as well. I installed a separate app (WinMerge) just for diffs. I might move to the 32-bit version of PSPad if it doesn't have the same issue.
Edited 2 time(s). Last edit at 2020-04-17 08:26 by omega7.
