You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.3 (377) English
#1 PSPad unicode 5.0.3 (377) English
Posted by: pspad | Date: 2020-02-09 15:51 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.3 (375)
News:
Compiler - if you run compiler and not Catch program output is selected, compiler window won't be hidden
Code explorer - ESC closes Code explorer. Removed.
parameter Statusbar functions require DblClick instead of SingleClick (Program settings / Program 2) has influence of the top editor ruller behavior too.
ASCII chart - new button CP as editor - this buttons sets content of ASCII chart into same CP as current editor window. Note, that ASCII chart works with singlebyte encodings only, not with UTF-xxx
Code explorer fix after new regular expression library implementation
HEX editor copy/paste in text part
System integration into context menu for limited user
ASCII chart - Print button changes label when Coda page was changed
exception when bigger amount of files was closed one by one
#2 Re: PSPad unicode 5.0.3 (377) English
Posted by: Ilya | Date: 2020-02-10 07:01 | IP: IP Logged
Confirmed for TclTk. Thank you!
#3 Re: PSPad unicode 5.0.3 (377) English
Posted by: Professor Bernd | Date: 2020-02-14 10:41 | IP: IP Logged
News:
That was a very good idea. Thank you.
