You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.3 (375) English
Posted by: pspad | Date: 2020-02-01 12:45 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.3 (371)
News:
Regular expressions - library based on Perl syntax was replaced with library supporting PCRE syntax
New user highlighter for ASAR assembler (David Wilson)
Computer suspend - FTP is disconnected.
Computer suspend - new modified files are saved in %Temp%\PSPad\Resume folder
reduce Windows flicker when you restore PSPad from minimized to maximized state
HEX editor - paste text into HEX part, copied from external source (e.g. Excel)
fixed behavior when PSPad is minimized to Tray icon
Posted by: Gabriel_ACE | Date: 2020-02-03 13:20 | IP: IP Logged
Excellent!.
Only you forgot to include the new version of spanish translation
Best Regards!
Posted by: PGomersall | Date: 2020-02-03 15:30 | IP: IP Logged
Jan,
I can confirm that the tray behavior has been fixed. PSPad now restores to the foreground on monitor it was closed or minimized from.
Posted by: pspad | Date: 2020-02-03 15:49 | IP: IP Logged
Gabriel_ACE:Excellent!.Only you forgot to include the new version of spanish translation
Best Regards!
Gabriel, please I didn't follow translators forum. Did you send me translation by mail?
Posted by: Ilya | Date: 2020-02-04 06:35 | IP: IP Logged
The Code Explorer of Tcl/Tk had been broken in 375 (32b and 64b both). In 363 it's OK.
Take the following script to debug:
proc putsArr {tok indx} {
} proc GetUserId {} {
} proc StripHtmlTags { htmlText } {
I sent a screenshot to ''.phorum_html_encode('support@pspad.com').''
Edited 1 time(s). Last edit at 2020-02-04 06:44 by Ilya.
Posted by: pspad | Date: 2020-02-04 06:46 | IP: IP Logged
Regular expression library was replaced in 375. It can have influence of many things, including the Code explorer.
I will check it.
Posted by: pspad | Date: 2020-02-04 07:25 | IP: IP Logged
Ilya:The Code Explorer of Tcl/Tk had been broken in 375 (32b and 64b both). In 363 it's OK.
Problem found and fixed.
Do you want to add parameters into function list too?
There can be list of function as before or list of function with parameters
Posted by: Ilya | Date: 2020-02-04 14:33 | IP: IP Logged
pspad:Do you want to add parameters into function list too?
List of functions as before is better for me.
On the other hand, can it be done configurable?
Posted by: Gabriel_ACE | Date: 2020-02-06 15:27 | IP: IP Logged
pspad:Gabriel_ACE:Excellent!.Only you forgot to include the new version of spanish translation
Best Regards!
DONE
please, take my suggestion into consideration
