You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.3 (375) English
#1 PSPad unicode 5.0.3 (375) English
Posted by: pspad | Date: 2020-02-01 11:45 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.3 (371)
News:
Regular expressions - library based on Perl syntax was replaced with library supporting PCRE syntax
New user highlighter for ASAR assembler (David Wilson)
Computer suspend - FTP is disconnected.
Computer suspend - new modified files are saved in %Temp%\PSPad\Resume folder
reduce Windows flicker when you restore PSPad from minimized to maximized state
HEX editor - paste text into HEX part, copied from external source (e.g. Excel)
fixed behavior when PSPad is minimized to Tray icon
#2 Re: PSPad unicode 5.0.3 (375) English
Posted by: Gabriel_ACE | Date: 2020-02-03 12:20 | IP: IP Logged
Excellent!. grinning smiley Only you forgot to include the new version of spanish translation sad smiley
forum.pspad.com
Best Regards!
#3 Re: PSPad unicode 5.0.3 (375) English
Posted by: PGomersall | Date: 2020-02-03 14:30 | IP: IP Logged
Jan,
I can confirm that the tray behavior has been fixed. PSPad now restores to the foreground on monitor it was closed or minimized from.
#4 Re: PSPad unicode 5.0.3 (375) English
Posted by: pspad | Date: 2020-02-03 14:49 | IP: IP Logged
Gabriel_ACE:
forum.pspad.com
Best Regards!
Gabriel, please I didn't follow translators forum. Did you send me translation by mail?
#5 Re: PSPad unicode 5.0.3 (375) English
Posted by: Ilya | Date: 2020-02-04 05:35 | IP: IP Logged
The Code Explorer of Tcl/Tk had been broken in 375 (32b and 64b both). In 363 it's OK.
Take the following script to debug:
proc putsArr {tok indx} {
proc GetUserId {} {
proc StripHtmlTags { htmlText } {
I sent a screenshot to ''.phorum_html_encode('support@pspad.com').''
Edited 1 time(s). Last edit at 2020-02-04 05:44 by Ilya.
#6 Re: PSPad unicode 5.0.3 (375) English
Posted by: pspad | Date: 2020-02-04 05:46 | IP: IP Logged
Regular expression library was replaced in 375. It can have influence of many things, including the Code explorer.
I will check it.
#7 Re: PSPad unicode 5.0.3 (375) English
Posted by: pspad | Date: 2020-02-04 06:25 | IP: IP Logged
Ilya:
Problem found and fixed.
Do you want to add parameters into function list too?
There can be list of function as before or list of function with parameters
#8 Re: PSPad unicode 5.0.3 (375) English
Posted by: Ilya | Date: 2020-02-04 13:33 | IP: IP Logged
List of functions as before is better for me.
On the other hand, can it be done configurable?
#9 Re: PSPad unicode 5.0.3 (375) English
Posted by: Gabriel_ACE | Date: 2020-02-06 14:27 | IP: IP Logged
Gabriel_ACE:
forum.pspad.com
Best Regards!
DONE
please, take my suggestion into consideration winking smiley
forum.pspad.com
