You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.1 (283) English
Posted by: pspad | Date: 2018-08-05 07:18 | IP: IP Logged
EnoSat:64b binary show as 5.0.1.282
Maybe my mistake, but it's same as 32b - compiled in the same moment.
Posted by: bruste | Date: 2018-08-06 11:25 | IP: IP Logged
pspad:Fixes:
Project tree - nodes indentation
Same issue in "Search in Files Results"
Another issue, opening this xsd pspad hangs
www.agenziaentrate.gov.it
Edited 1 time(s). Last edit at 2018-08-06 11:35 by bruste.
Posted by: gwinkless | Date: 2018-08-06 13:58 | IP: IP Logged
pspad:Changes to 5.0.0 (277)
Thanks for this
Posted by: Gabriel_ACE | Date: 2018-08-06 14:38 | IP: IP Logged
I found another problem:
LINE 360 for LANGUAJE COBOL.
perform description has the same color as coment. but when I add at first a number
the color change to the correct format (like line 358)
Posted by: RickH | Date: 2018-08-06 15:10 | IP: IP Logged
There seems to be a problem in the php highlighter: the initial "<?" of the php opening tag is invisible, although it takes up space and will appear if selected. The closing tag ("?>"), if used, is also invisible but will also appear if selected. This is true for both new and old files. The rest of the hightlighter works as expected.
Posted by: RickH | Date: 2018-08-06 17:30 | IP: IP Logged
Additionally, the second line of open-file tabs covers line #1 of the working file.
Posted by: pspad | Date: 2018-08-06 17:41 | IP: IP Logged
RickH:Additionally, the second line of open-file tabs covers line #1 of the working file.
Can I have a screenshot please? And info about your resolution and DPI settings (100/125/150/...%)
Posted by: RickH | Date: 2018-08-06 18:18 | IP: IP Logged
1600x1200 1x (old school) win7 32bit. I added a blank line at the top of the file so you could also see that the "<?" is missing. I also just noticed that the top project folder's name, which is selected, is missing. Lots better than the previous build, though.
Edited 2 time(s). Last edit at 2018-08-06 18:25 by RickH.
Posted by: hhoefling | Date: 2018-08-06 18:35 | IP: IP Logged
Here same.
W7/64 1600x1200 125%
If selected the <? and ?> are visible.
It seems that text color and backgroundcolor are the same.
by HH
Posted by: Andreas | Date: 2018-08-06 21:43 | IP: IP Logged
with 5.0.1 (283) but also with 5.0.1 (281)
not with 5.0.0 (277)
PSPad starts to run with CPU at about 30% after clicking on the code explorer icon with this PHP file raw.githubusercontent.com
I have to terminate the pspad task as pspad did not react anymore.
Strange is, that also my Firefox task (FF56) starts to run on about 20% CPU. After killing the pspad task Firefox starts running normal again.
