You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2674) English
Goto Page: 1 2 Next
#1 PSPad unicode 4.6.0 (2674) English
Posted by: pspad | Date: 2015-09-26 21:07 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2671)
News
MS-Dos batch highlighter was renamed to Windows Shell Script
JSON - new user highlighter including code explorer
BAT highlighter - label in CALL and variables include modifiers
Right edge wasn't visible with cursor edge active
Right dock panel width change possibility
#2 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pythonui | Date: 2015-09-28 05:43 | IP: IP Logged
Working great ! smiling smiley
Thanks
#3 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pythonui | Date: 2015-09-28 11:18 | IP: IP Logged
JSON Code explorer is working great but problem with following type of JSON :
Sample JSON : dpaste.de
Thanks
Edited 1 time(s). Last edit at 2015-09-28 11:18 by pythonui.
#4 Re: PSPad unicode 4.6.0 (2674) English
Posted by: programmer9 | Date: 2015-09-28 11:30 | IP: IP Logged
The "Text to Find" and "Selected Directory" drop-down boxes of the "Select/Replace in Files..." function still don't update to show the latest search string or folder respectively at the top of the lists the next time the function is used. The "Select/Replace in Files..", for me, worked really well until changes were made a few builds ago, since then it has been broken in different ways.
PSPad 2674, Windows 7 64-bit Professional
Does no one else have this problem?
#5 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pspad | Date: 2015-09-28 15:37 | IP: IP Logged
pythonui:
Thanks
What's woring? I don't see any problem
#6 Re: PSPad unicode 4.6.0 (2674) English
Posted by: Freeman | Date: 2015-09-28 16:38 | IP: IP Logged
Yeah, it works! But... permanent vertical line is annoying... When coding, vertical line is needed only for indentation checks. Would you add a shortcut to make line visible only when some key is pressed?
#7 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pspad | Date: 2015-09-28 17:04 | IP: IP Logged
When you want to see line only from time to time, click on the top ruller to set right edge into position you want.
#8 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pspad | Date: 2015-09-28 20:35 | IP: IP Logged
Freeman:
What I can do for you is possibility to set right edge to cursor position with some shortcut.
#9 Re: PSPad unicode 4.6.0 (2674) English
Posted by: pythonui | Date: 2015-09-29 05:21 | IP: IP Logged
There is problem with 'ageBands' tag. There are two 'ageBands' information in one tag so it would display separately in code explorer like arrays indexing. I think you can understand what I am trying to say.
Thanks
#10 Re: PSPad unicode 4.6.0 (2674) English
Posted by: janaco | Date: 2015-10-02 08:57 | IP: IP Logged
since a while there is a bug when activating "Special Chars":
Numbers change position and every time a number is followed by a special char (€, %, $, ...) the number changes position with this char. I tried different fonts (Fixed Sys, Corier, Hack, Lucida,...) but nothing got better. In the above example I used Courier New
Is there a chance to reproduce this for others? I first saw this behavior on Win XP and now on Win8.1 too. And its a little bit more anoying winking smiley
Thanks, janaco
Goto Page: 1 2 Next
