You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.6.0 (2667) English
#1 PSPad unicode 4.6.0 (2667) English
Posted by: pspad | Date: 2015-08-06 05:58 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2665)
News
TiDy and PHP beautifier - possibility to define shortcuts for profiles. Format: [profile name*shortcut]
Right edge - possibility to set it highlighter depending (Highlighter settings)
Parameter %input% history for external application or compiler
BAT highlighter - fixed brackets in coditions with variables
#2 Re: PSPad unicode 4.6.0 (2667) English
Posted by: pythonui | Date: 2015-08-06 06:08 | IP: IP Logged
TiDy and PHP beautifier - possibility to define shortcuts for profiles. Format: [profile name*shortcut] Right edge - possibility to set it highlighter depending (Highlighter settings)
Big Thank You !! smiling smiley Working well !
Edited 1 time(s). Last edit at 2015-08-06 06:09 by pythonui.
#3 Re: PSPad unicode 4.6.0 (2667) English
Posted by: David in Delta | Date: 2015-08-06 10:29 | IP: IP Logged
I just installed developer build 4.6.0 (2667) on a Windows 10 machine. The Check HTML Code is still not available.
#4 Re: PSPad unicode 4.6.0 (2667) English
Posted by: pspad | Date: 2015-08-06 10:36 | IP: IP Logged
It isn't possible.
Check HTML code is available for HTML like languages - it means HTML multihighlighter, HTML and XHTML highlighters.
It has no sense to use HTML check for TXT e.t.c.
Are you sure you are running PSPad from folder where is PSPad.exe + Tidy.exe in same folder?
Developer builds contains missing files only - read the info in build page.
#5 Re: PSPad unicode 4.6.0 (2667) English
Posted by: programmer9 | Date: 2015-08-06 11:15 | IP: IP Logged
Thanks for the update.
However, it looks as though there is still a problem with Find In Files remembering the previous seach locations - the duplicate entries are no longer stored, which is good, but if I use the drop down box to select a previous location from the list (or even the entry from the top of the list) the search finds no matches unless, having selected the location, I edit it - for example by placing the cursor at the end of the location text, typing a space and then deleting the space - the find then works correctly.
#6 Re: PSPad unicode 4.6.0 (2667) English
Posted by: pspad | Date: 2015-08-06 11:39 | IP: IP Logged
PSPad never remembered search string in Find in files. But I will add this functionality.
It will depends of the Program settings / Tools: Search - fill in Search field with current/selected text
If this option is checked, PSPad will prefill current word under cursor or selected text. In case cursor will be out of any text, it will return previous search string
If this option is unchecked, PSPad will return always last used search string.
#7 Re: PSPad unicode 4.6.0 (2667) English
Posted by: programmer9 | Date: 2015-08-06 13:18 | IP: IP Logged
The problem isn't with the "Text to Find" field - this works just fine, previously searched text appears in the drop-down box and can be selected and it is found.
The problem is with the "Selected Directory" field.
There is no problem when just doing another "Search and/or replace in files" - the contents of the "Selected Directory" field is used to search the same location as on the last search.
However, if the drop-down box feature for the "Selected Directory" field is used to select one of the previously searched locations (even if it is the one from the head of the list) the search returns no results, UNLESS, having selected the location from the drop-down box, it is edited slightly (for example by the addition and deletion of a space character). If this is not done then the search returns no results. Also the next time the "Search and/or replace in files" is used the "Selected Directory" field is empty - whereas if the location had been edited on the last search (so that the search was successful) then the "Selected Directory" field will still be set to the location of the last search.
#8 Re: PSPad unicode 4.6.0 (2667) English
Posted by: pspad | Date: 2015-08-18 12:40 | IP: IP Logged
Problem with recent files was found and fixed. Wait for the next developer build
