You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.0 (2665) English
Goto Page: 1 2 Next
#1 PSPad unicode 4.6.0 (2665) English
Posted by: pspad | Date: 2015-06-14 17:48 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
Changes to 4.6.0 (2661)
News
Find in files dialog - new switch on dialog which allows let dialog open after search
Calculate block - improved different number format handling
Code explorer for QBasic
BAT highlighter - highlighting of the labels after CALL, exclamation variables, new conditional words
HTML check menu item problem was disabled in some cases
Parameter %input% history for external application or compiler
File attributes in files with unicode chars in file name
LaTex - highlight matching {} brackets
Code explorer for FiveWin detects CLASS in block comments
#2 Re: PSPad unicode 4.6.0 (2665) English
Posted by: mce | Date: 2015-06-14 18:09 | IP: IP Logged
Hi Jan,
The %input% duplicate entry doesn't seem to be fixed, it keeps adding the same value to the list.
Thanks,
Cristian
#3 Re: PSPad unicode 4.6.0 (2665) English
Posted by: pspad | Date: 2015-06-16 06:17 | IP: IP Logged
Helo Christian
You are right, I found another problem with recent list. Now I tested it and I hope this time it will be ok. Wait for the next build please.
#4 Re: PSPad unicode 4.6.0 (2665) English
Posted by: programmer9 | Date: 2015-06-23 08:51 | IP: IP Logged
The "Selected Directory" option in "Search/Replace in Files" used to show the most recently used directory at the top of the drop-down list with other unique directory names in chronological order of access below. Now there appears to be no sorting of the list to weed out duplicates. For example if I search in "C:\Data" 10 times the first 10 entries of the drop-down list will be "C:\Data". Has something changed in PSPad or has something changed in my system?
Or is this what the previous two entries are about?
Windows 7 64-bit Professional with PSPad build 2665 in C:\Program Files (x86)
Edited 1 time(s). Last edit at 2015-06-23 08:52 by programmer9.
#5 Re: PSPad unicode 4.6.0 (2665) English
Posted by: pspad | Date: 2015-06-23 08:57 | IP: IP Logged
It was bug in PSPad. It should be fixed in the next build
#6 Re: PSPad unicode 4.6.0 (2665) English
Posted by: programmer9 | Date: 2015-06-24 07:34 | IP: IP Logged
Many thanks
#7 Re: PSPad unicode 4.6.0 (2665) English
Posted by: Zmy | Date: 2015-07-06 16:23 | IP: IP Logged
Hello.
Develop, please, to be able to use regular expressions in the dialog Search and Replace in files
#8 Re: PSPad unicode 4.6.0 (2665) English
Posted by: Zmy | Date: 2015-07-07 05:34 | IP: IP Logged
Hi
I miss hotkeys for runing macros
#9 Re: PSPad unicode 4.6.0 (2665) English
Posted by: pspad | Date: 2015-07-07 05:49 | IP: IP Logged
There are 4 hotkeys to assign macros. Open Macro manager and assign it.
For current recorded macro F5 is assigned automatically
#10 Re: PSPad unicode 4.6.0 (2665) English
Posted by: Zmy | Date: 2015-07-07 07:23 | IP: IP Logged
Thank you, but I do very little 4. I would like to, though, would be 8
Goto Page: 1 2 Next
