You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.8 (2471) English
Posted by: IanCabell | Date: 2014-05-15 20:05 | IP: IP Logged
Highlight matching brackets seems to have stopped working?
I recently upgraded (?) to Windows 8.1, and had to upgrade PSPad as well. I've tried both this build and 2469 and checked the "Settings -> Program Settings -> Editor (part 1)" to make sure the "Highlight Matching Brackets" is on. But it doesn't seem to be highlighting them anymore.
Thanks,
--Ian
Posted by: MatteoNigro | Date: 2014-05-30 09:04 | IP: IP Logged
Hello jan,
in the new version, can you enter a chance to see in real time while you write the auto-completion window [Ctrl + J] (As in Visual Basic Studio)? It would be fantastic and greatly reduce the time of writing the code.
Thank you and congratulations for your software!
Posted by: pspad | Date: 2014-05-30 10:48 | IP: IP Logged
Autocompletion can be fired automatically - program settings / Editor 2 - set autocomplete delay on the bottom of settings page to any nonzero time in ms
Posted by: gwinkless | Date: 2014-05-30 12:01 | IP: IP Logged
pspad:Check document changes function was fixed
I'm assuming this was meant to fix the problem with ANSI saves "File contents were saved: reload?" (as per this thread): if so, I can report that it now works perfectly for me, thanks for your hard work!
Geoff
Posted by: MatteoNigro | Date: 2014-06-05 08:16 | IP: IP Logged
Thanks, in the meantime, in fact I was able to find the parameter
Edited 1 time(s). Last edit at 2014-06-05 08:16 by MatteoNigro.
