You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.8 (2481) English
Posted by: pspad | Date: 2014-06-01 18:07 | IP: IP Logged
Download links (2.7 MB):
code.fosshub.com
Info: File locking support for more team cooperation is near finished
Changes to 4.5.8 (2471)
News
FTP - added support for MLSD file list (standard and it should speed up listing in big folders). For old servers without MLSD command support enable old file listing support in the FTP connection settings (new option)
FTPS - in the log is SSL library version and used server certificate info
HEX editor - added possibility print content using PrintPreview
Updated libraries Synapse (FTP, HTTP communication), MP Hex editor
PHP highlighter - added highlighting of `command`
Code explorer automatical refresh is initiated with File save
MSDos bat highlighter - fixed pairt bracked highlight
Object Code explorer - missing procedures caused by block comments
File R/O attribute was removed after file save
FTPS - fixed file listing on VSFTP servers
Posted by: carbonize | Date: 2014-06-02 19:41 | IP: IP Logged
MLSD not working for my server in PSPad despite it working fine in FileZilla. Could it be down to the -la switch you are putting on the end?
FileZilla sends
CWD /public_html
250 OK. Current directory is /public_html
PWD
257 "/public_html" is your current location
TYPE I
200 TYPE is now 8-bit binary
PASV
227 Entering Passive Mode (208,76,82,62,173,23)
MLSD
150 Accepted data connection
226-Options: -a -l
226 114 matches total
PSPad is sending
CWD /public_html
TYPE A
200 TYPE is now ASCII
PASV
227 Entering Passive Mode (208,76,82,62,179,163)
MLSD -la
226-Options: -a -l
226 0 matches total
If I send any other command then using the RAW FTP command option PSPad just locks up until the connection times out.
Also just noticed that I have binary transfer mode ticked yet PSPad is saying to use ASCII. Ignore that I see you are setting it before the file transfer although it should be set at the initial connection.
Carbonize
Posted by: carbonize | Date: 2014-06-02 20:38 | IP: IP Logged
Fixed it. The issue lies with the 'Show hidden files' option. If I disable it the extra switches are not added to the MLSD command and my files get listed as expected.
I am however getting a . and two .. directories listed.
Carbonize
Edited 1 time(s). Last edit at 2014-06-02 20:39 by carbonize.
Posted by: pspad | Date: 2014-06-03 03:37 | IP: IP Logged
I will disable this option for MLSD command
Posted by: ok1 | Date: 2014-06-04 00:37 | IP: IP Logged
Minor bug this release, every time I open the toolbar has "forgotten" its layout and is broken over two rows.
Not a big issue as I leave it open most of the time & it only takes a few seconds to re-arrange. Any ideas ?
Posted by: pspad | Date: 2014-06-04 10:33 | IP: IP Logged
ok1:Minor bug this release, every time I open the toolbar has "forgotten" its layout and is broken over two rows.Not a big issue as I leave it open most of the time & it only takes a few seconds to re-arrange. Any ideas ?
You can switch off/on any toolbar from the menu View / Tollbars
If the settings isn't remembered, it means PSPad has no rights to write into it's config file. Didn't you installed PSPad as portable into program files? Is other settings remembered?
Posted by: vserghi | Date: 2014-06-04 12:41 | IP: IP Logged
I'm also seeing the issue with the toolbars. I am admin on my XP laptop. The new files were copied into the install directory.
I have the first five toolbars enabled all on one row. I close PsPad, reopen it, and the toolbar positions are not saved. They are now spread across two rows with a large gap between the second row toolbars.
Other settings seem to be remembered.
Vas
Posted by: pspad | Date: 2014-06-04 12:59 | IP: IP Logged
1. go to program settings / Backup and look where the path for configuration leads
2. can you make some screenshot before closing and after PSPad restart?
Posted by: Freeman | Date: 2014-06-05 16:00 | IP: IP Logged
vserghi:I'm also seeing the issue with the toolbars.
I confirm this bug.
Edited 2 time(s). Last edit at 2014-06-05 16:36 by Freeman.
Posted by: therium | Date: 2014-06-05 16:12 | IP: IP Logged
Quote:Code explorer automatical refresh is initiated with File save
Yay, thanks!
I didn't realize you did so much work on each release. We appreciate it.
