You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.8 (2461) English
Posted by: pspad | Date: 2013-10-18 11:22 | IP: IP Logged
This build was revoked and replaced with 2462 build:
forum.pspad.com
Download links (2.7 MB):
31.31.78.126
www.dropbox.com
Changes to 4.5.8 (2457)
News
Added possibility to use wildcard in parameter (c:\files\*.txt). Wildcard can be contained in file name only, not in the path. Number of files is limited to 100.
Added possibility to set compatibility of the internel IE browser to IE7 .. IE10 (program settings / system integration)
File information - added possibility to copy list of words only (Shift+Ctrl+C or right mouse)
Added Oracle keywords flash_cache, cell_flash_cache
Added HTML5 tags into html highlighter
Added option to save all files before external application run (highlighter settings and project settings)
Added option to run external application with file or selected text (highlighter settings and project settings)
Program title contains project name if project is open
Added possibility to individually set File tab color (righ mouse menu on file tab or menu Window). Color is stored if save file state option is enabled in program settings / Files and dirs
Fixed problem with project file containing empty line
Fixed problem if you create project file from drive root
VBScript Code explorer - fixed missing "property get xxx"
Edited 1 time(s). Last edit at 2013-10-20 17:45 by pspad.
Posted by: pspad | Date: 2013-10-18 12:30 | IP: IP Logged
Delete please file PSCache.bin
This file doesn't contains tab color information for earliear open files. Tab colors are colored randomly.
I am sorry, but I found it after build publishing.
Posted by: Andreas | Date: 2013-10-18 13:08 | IP: IP Logged
Ah, that was the reason why some of my tabs were black
Thank you.
Posted by: Manfred62 | Date: 2013-10-18 13:56 | IP: IP Logged
at start I get this:
Quote:the ordinal number 3906 was not found in DLL "LIBEAY32.dll"
WIN 7 64bit, PSPad portable
PSPad 4.5.9 (2525)
Posted by: hankejh | Date: 2013-10-18 13:59 | IP: IP Logged
Thanks for the update, Jan!
I have no PSCache.bin file -- black tabs showed up and I right-click corrected them to white (no color).
Also noticed the tab color menu option is shown as "Barva záložky" in the right-click menu on the English download.
I didn't check whether the ingkcpos cursor enhancement extension is in this release -- I've uploaded a new version to the PSPad extensions collection.
Posted by: pspad | Date: 2013-10-18 15:08 | IP: IP Logged
Manfred62:at start I get this:Quote:the ordinal number 3906 was not found in DLL "LIBEAY32.dll"WIN 7 64bit, PSPad portable
You have installed in your system old version of OpenSSL library.
Please download this package:
www.pspad.com
and unpack it into PSPad folder.
You will get portable FTPS access
Posted by: pspad | Date: 2013-10-18 15:09 | IP: IP Logged
hankejh:Thanks for the update, Jan!I have no PSCache.bin file -- black tabs showed up and I right-click corrected them to white (no color).
Sorry for this. I will prepare update.
Look for PSCache.bin in %appdata%\PSPad folder - in your user profile
Posted by: Manfred62 | Date: 2013-10-19 07:08 | IP: IP Logged
pspad:You have installed in your system old version of OpenSSL library.
www.pspad.com
and unpack it into PSPad folder.You will get portable FTPS access
Tried it, but still the same popup. The same files were already there, but I overwrited them anyway.
PSPad 4.5.9 (2525)
Posted by: pspad | Date: 2013-10-20 07:07 | IP: IP Logged
Manfred, do you use software like OpenVPN? Is possible you update it?
It looks like you have installed and registered old version of OpenSSL in your operating system.
I don't know why PSPad doesn't accept library from it's folder. I must check it.
Posted by: Manfred62 | Date: 2013-10-20 07:47 | IP: IP Logged
I have XAMPP 1.8.2. There's OpenSSL Library Version: OpenSSL 0.9.8y 5 Feb 2013. Could this cause the problem?
Maybe it's possible to config PSPad to only use it's own library? Think, that will be the best solution.
regards Manfred
PSPad 4.5.9 (2525)
