You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.8 (2453) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.8 (2453) English
Posted by: pspad | Date: 2013-05-12 07:08 | IP: IP Logged
Thank you.
I will try to investigate what can I do. I compared current build with 2433 and I didn't find any change what can have influence.
#22 Re: PSPad unicode 4.5.8 (2453) English
Posted by: ino | Date: 2013-05-12 07:26 | IP: IP Logged
Jan,
I have sent you a private message with all application error logs which appears during drawing Format menu.
Thank you for your investigation!
#23 Re: PSPad unicode 4.5.8 (2453) English
Posted by: mdes | Date: 2013-09-29 11:37 | IP: IP Logged
I had the same problem with the French accentuated characters in v4.5.8 (2457).
I solved it by:
- Changing the language to "English".
- Editing the "Lang\French.INI" file with PSPad.
- Selecting "ANSI" as the file format (it was "UTF-8").
- Saving the file.
- Changing back the language to French.
All the accentuated characters were good.
Hope this help ;)
Michel.
#24 Re: PSPad unicode 4.5.8 (2453) English
Posted by: pspad | Date: 2013-09-29 13:23 | IP: IP Logged
You are right. It's my fault, I accidentally saved source French translation in UTF-8.
#25 Re: PSPad unicode 4.5.8 (2453) English
Posted by: pspad | Date: 2013-12-05 08:03 | IP: IP Logged
Fix will be available in the next developer build
