You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.5 (2390) English
Posted by: wimb | Date: 2010-06-03 08:25 | IP: IP Logged
pspad:I can't confirm, it works for me.
I tested it in JavaScript highlighter and both comments was show as comments on first column too.
Ouch, sorry for the inconvenience
Now it works for me too. Apparently when switching to a new OS (w7) my pspad installation got screwed up. After a clean install with the latest rev commenting works.
Thanks for your time looking into this.
WimB
Posted by: pspad | Date: 2010-06-03 13:26 | IP: IP Logged
jbyrne:File change detection now not working under Windows 7
Just tested under Win7 and it works.
There is a problem if you close tab with middle mouse - from this point file change detection stops working.
Posted by: jbyrne | Date: 2010-06-04 07:50 | IP: IP Logged
I just re-tested it and it seems to be working again.
Must have been some environment issue.
Thanks
JB
Posted by: holger | Date: 2010-06-07 06:36 | IP: IP Logged
pspad:Just tested under Win7 and it works.
Little correction:
file change detection stops working since any way of closing a file ...
I figure out: to reactivate the set of CheckDeleted=1 (and maybe any action like setting autorefresh) must be done.
May this be fixed in the next build?
Thanks!
Edited 1 time(s). Last edit at 2010-06-07 06:37 by holger.
Posted by: hamasaki | Date: 2010-06-10 14:39 | IP: IP Logged
The Fullscreen option (F11) doesn`t seem to work in the latest build. Not sure if this is a Windows7 issue as I`ve just upgraded.
dc
Posted by: PGomersall | Date: 2010-06-10 15:49 | IP: IP Logged
F11 (Full Screen) Working for me on W7 x64.
Pete
Posted by: holger | Date: 2010-06-11 05:55 | IP: IP Logged
hamasaki:The Fullscreen option (F11) doesn`t seem to work in the latest build. Not sure if this is a Windows7 issue as I`ve just upgraded.dc
Is Aero Snap active?
Edited 1 time(s). Last edit at 2010-06-11 05:57 by holger.
Edited 2 time(s). Last edit at 2010-06-11 05:58 by holger.
