You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2390) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.5 (2390) English
Posted by: pspad | Date: 2010-05-30 17:09 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.5 (2389)
News
added FTP support for z/VM - vm/cms
new option for detection deleted files in [Special settings section]: CheckDeleted. Default is off.
Fixes
fixed CSS highlighter
file change detection using GetFileInformationByHandle() API function
all window redraw during open files from outside editor
Save main window position in menu Settings was disabled if no file was open
#2 Re: PSPad unicode 4.5.5 (2390) English
Posted by: F170 | Date: 2010-05-30 19:03 | IP: IP Logged
Great
#3 Re: PSPad unicode 4.5.5 (2390) English
Posted by: autocart | Date: 2010-05-31 07:05 | IP: IP Logged
Hi pspad,
thank you for the great work.
Please, could you take a look at this issue, which (still ?) does not work in this latest beta:
http://forum.pspad.com/read.php?2,50142#msg-53988
Thank you.
#4 Re: PSPad unicode 4.5.5 (2390) English
Posted by: papi | Date: 2010-05-31 08:27 | IP: IP Logged
Thanks for this fix: 'all window redraw during open files from outside editor'
Now i am happy again to use the latest version!
Thank you!
#5 Re: PSPad unicode 4.5.5 (2390) English
Posted by: smoon177 | Date: 2010-05-31 09:12 | IP: IP Logged
Sometimes, Reformat HTML code function doesn't format code perfectly. Some tags seem to be missed. After formatting html code, some spaces appear inside html tag. Example: <td>, <label>, <hr>...
I will show deep gratitude if you can fix this bugs
Thanks
#6 Re: PSPad unicode 4.5.5 (2390) English
Posted by: pspad | Date: 2010-05-31 11:24 | IP: IP Logged
smoon177:
Thanks
Send me some examples please. I don't write HTML
#7 Re: PSPad unicode 4.5.5 (2390) English
Posted by: wimb | Date: 2010-05-31 11:59 | IP: IP Logged
Thanks for all your work.
Unfortunately the javascript highlighter still doesn't show comments where the comment tag starts at the first column. For example (remove quotes):
"// JavaScript document"
is not displayed as comment where
" // JavaScript document"
is. Same for /* at the beginning of a line.
Edited 1 time(s). Last edit at 2010-05-31 12:02 by wimb.
#8 Re: PSPad unicode 4.5.5 (2390) English
Posted by: pspad | Date: 2010-05-31 12:49 | IP: IP Logged
I didn't correct it, it wasn't in changelog
#9 Re: PSPad unicode 4.5.5 (2390) English
Posted by: c3k | Date: 2010-05-31 16:49 | IP: IP Logged
Fixes
Just tested new version, still can't get the expected results... :(
Have you try my test in this post:
www.youtube.com
forum.pspad.com
#10 Re: PSPad unicode 4.5.5 (2390) English
Posted by: pspad | Date: 2010-06-01 09:37 | IP: IP Logged
wimb:
I can't confirm, it works for me.
I tested it in JavaScript highlighter and both comments was show as comments on first column too.
