You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2383) English
#21 Re: PSPad unicode 4.5.5 (2383) English
Posted by: human | Date: 2010-02-03 16:32 | IP: IP Logged
PSpad checks file changes if comes from nonactive to active state, e.g. application switching.
Wouldn't it be useful to check directly before saving, too?
human
#22 Re: PSPad unicode 4.5.5 (2383) English
Posted by: pspad | Date: 2010-02-03 17:58 | IP: IP Logged
Maybe will be usefull to use some CSV system if more then one people work on same source file
#23 Re: PSPad unicode 4.5.5 (2383) English
Posted by: c3k | Date: 2010-02-03 19:06 | IP: IP Logged
Yes, CVS is the best choice, but after 2357 is very easy to overwrite a file!
Try to open the same file in two instances, when you save in one and put the focus in the other it say nothing!
2357 works perfectly throwing an alert to reload the file!
is difficult find what is changed and correct it?
#24 Re: PSPad unicode 4.5.5 (2383) English
Posted by: c3k | Date: 2010-02-03 19:14 | IP: IP Logged
I've just retry with a clean 2283 installation.
1stInstance: new txt file saved
2stInstance: open the same txt file saved, modified and saved
1stInstance: get the change, reload, modify and save
2stInstance: no alert, change and save
1stInstance: no alert, change and save
it seems to always catch the first, then is very very difficult to get a change alert (but some times it comes up)
i'm on XP SP3, if you need more info, just ask
#25 Re: PSPad unicode 4.5.5 (2383) English
Posted by: c3k | Date: 2010-02-04 08:10 | IP: IP Logged
same on vista SP2...
#26 Re: PSPad unicode 4.5.5 (2383) English
Posted by: ino | Date: 2010-02-04 08:22 | IP: IP Logged
c3k:
I confirm this issue. There used to be a message: "rs_FileWasChangedQuestion=File Contents were Changed. Reload ?"
which does not appear - file change is not detected at all.
#27 Re: PSPad unicode 4.5.5 (2383) English
Posted by: holger | Date: 2010-02-05 12:22 | IP: IP Logged
I get the following error:
Exception description:
If I have the FileOpen Dialog open and Drop a File from that in the Mainwindow, I get this Exception.
The Error should be produceable.
Exception class:
Exception address:
Stack list, generated 05.02.2010 13:13:56
Deleted.
Please send such logs to the e-mail address found in PSPad help menu.
Thanks
the mod
Program : C:\Programme\PSPad editor\PSPad.exe 4.5.5 (2383)
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 3"
Processor: Intel, Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz, 2120 MHz MMX
Display : 1920x1200 pixels, 32 bpp
Active Controls Hierarchy:
TfPSPad "fPSPad"
Hope this Information is useful winking smiley
Edited 1 time(s). Last edit at 2010-04-25 14:03 by Stefan.
#28 Re: PSPad unicode 4.5.5 (2383) English
Posted by: jimj | Date: 2010-02-07 06:27 | IP: IP Logged
for new file extension TXT is set when Highlighter is switched off in Syntax change dialog
Is this supposed to fix the uppercase TXT extension bug described here.
I still the the uppercase TXT extension problem with PSPad 4.5.5 (2303). To reproduce I have a clean install of Windows 7 Pro 64bit. I installed 4.5.4 (without running it) and and then updated to 4.5.5. At this point my new txt extensions are still lower case. I then go to "Settings->System integration" and check "Open TXT files". Now when I create a new text file in Windows Explorer its extension TXT is all uppercase.
Fortunately the fix described in the original thread still works.
#29 Re: PSPad unicode 4.5.5 (2383) English
Posted by: ellocco | Date: 2010-02-10 18:35 | IP: IP Logged
I had sever problems to copy PSPadShell.dll
into the PSPaD directory.
The message was: The file is shared with
a process. (The message was in german language)
I had to start the machine in the secure modus
with terminal prompt.
I don't know, if it is a PSPaD issue or if it
is a MS-XP-Windows issue.
Regards,
stefan
#30 Re: PSPad unicode 4.5.5 (2383) English
Posted by: MrSpock | Date: 2010-02-10 20:19 | IP: IP Logged
ellocco:
into the PSPaD directory. [...]
The Explorer extension PSPadShell.dll is always in use while Windows is running. Unregistering the old dll before copying the new one should usually help.
