You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2357) English
Posted by: pspad | Date: 2009-08-16 17:27 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
pspad.siliconhill.cz
Changes to 4.5.4 (2356)
News
InnoSetup highlighter update - new keywords and flags
new function - Detach file from FPT - if you open file from FTP, you can edit it locally only without automatically save it to FTP
new option if FTP settings allows you keep connection with random commands
new user highlighter for SIEMENS STEP7 industrial automation controller language (Wolfgang T. Url, DynaByte Engineering Url)
Corrections
XML Code explorer - some XML form (one line XML) freezes PSPad
FTP log doesn't scroll to last line automatically
Main form position after start
Active tab setting after close files right or left
FTP icon on the file tab after file was saved to FTP
Multiline file tabs was displayed incorrectly in some cases
Removing unnumbered bookmark doesn't have influence to bookmarks list
Autorefres for new files
Import FTP settings from FileZilla with FTP servers groups
PSPad start with dots in path
Posted by: Zappa | Date: 2009-08-17 02:20 | IP: IP Logged
2357 remembers the windows size, but it does not remember the windows position anymore (i.e. closed on second monitor, but reopens somewhere left on first monitor).
Posted by: wimb | Date: 2009-08-19 10:18 | IP: IP Logged
(Maybe this is also in previous builds).
After updating to build 2357, the key mapping for 'Remove File From Project' was removed. I've tried to reset it to Shift+Ctrl+Del, but noticed that 'Del' is not able to be entered. I could set it with Direct edit.
I want to do the same for 'Remove Folder', but I cannot find it in the Direct edit window. Also search doesn't work in this window.
As a suggestion I would rather have a plain text file to be edited for the key mappings, which could be done in pspad itself.
Posted by: pspad | Date: 2009-08-19 13:17 | IP: IP Logged
Program settings / KeyMap / Direct edit
Posted by: F170 | Date: 2009-08-20 15:42 | IP: IP Logged
PSPad native for OS X pleeeease!
Posted by: pspad | Date: 2009-08-20 17:01 | IP: IP Logged
F170:PSPad native for OS X pleeeease!
Borland Delphi compiler for OS X pleeease!
Posted by: merendina | Date: 2009-08-20 21:24 | IP: IP Logged
My first post...
Well thank you for PSPad, i use it everyday
1) Seems that the state of the "Use random command" in ftp connection options is always forced to checked, unchecking it and going back to options and is checked again.
2) in this and in the old versions i've tried, using ftp over ssl/tls is very slow (i'm using vsftpd on a linux server) openssl dlls are in place (also tryed new versions, but same behaviour)
i'm using active(also trued passive) ftp on tls (also tryed ssl) seems that the data connection to retrieve the file list connect (from pspad to server) and wait a lot (~20sec) before is transferred, bet when get downloaded all show up quickly
with FileZilla v2 and v3 all works fine with implicit ssl/tsl!
best regards
Posted by: carbonize | Date: 2009-08-23 18:10 | IP: IP Logged
Using Windows 7 when I press Ctrl + Shift + E to open up the function explorer I get System Error. Code 87
I have emailed the log to you
Then when I click Mail log I got an error window saying Index is out of range.
Carbonize
Edited 1 time(s). Last edit at 2009-08-23 18:11 by carbonize.
Posted by: Bart | Date: 2009-08-27 17:55 | IP: IP Logged
pspad:F170:PSPad native for OS X pleeeease!
What about Delphi Prism (Delphi .NET)/ CodeGear RAD Studio? In combination with Mono it would bring PSPad to Linux and Mac OS X.
en.wikipedia.org
Karamba!
Bart.
Posted by: pspad | Date: 2009-08-27 18:08 | IP: IP Logged
Bart:What about Delphi Prism (Delphi .NET)/ CodeGear RAD Studio? In combination with Mono it would bring PSPad to Linux and Mac OS X.
en.wikipedia.org
It's same request as rewrite PSPad into another programming language.
Native object pascal is different from .NET
The better way is use FreePascal, but it means hundreds work hours
