You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2314) English
Posted by: pspad | Date: 2008-03-26 12:10 | IP: IP Logged
For all people with slow loading problem.
Please send me your PSPad.INI and some small description.
I need to find some dependences.
Posted by: pypardo | Date: 2008-03-26 15:22 | IP: IP Logged
I can confirm pspad is (very) slow in this release.
I have to come back to 2309.
It seems that 2309 was slower than previous release, but i've no benchmark.
In 2314, I can see the cursor refreshing the screen !
My config: winxp sp2
best regards
pierre
Posted by: Karl | Date: 2008-03-26 16:48 | IP: IP Logged
pspad:For all people with slow loading problem.
Please send me your PSPad.INI and some small description.I need to find some dependences.
Well, I already dissected my PSpad.ini a while ago, and, as you perhaps remember, the problem back then was WordWrap. If on r2310,11... are dead slow; if off they were almost as fast as before.
For the time being I have given up on this Seems I am stuck with r2309.
Posted by: Campino | Date: 2008-03-26 21:50 | IP: IP Logged
Hi!
I dont know if Im right here, sorry
But is it possible to add a feature like this:
I dont know how its called, but you can hide text with it. I know it from Visual Studio for example.
Campino
Posted by: raeubi | Date: 2008-03-27 08:46 | IP: IP Logged
Campino:... to add a feature like ...
This is code folding.
That was discussed here in the forum unsuccessful many times.
(Pls. use forum search with code folding)
Edited 2 time(s). Last edit at 2008-03-27 08:49 by raeubi.
Posted by: zeeric | Date: 2008-03-27 10:37 | IP: IP Logged
hello
there is a bug in the spell corrector
if you write :
idiot => good
l'idiot => false
l"idiot => good
the ' must be used as a separator, so l'idiot must be good
thanks for your editor ;)
Posted by: Bart | Date: 2008-03-27 16:54 | IP: IP Logged
Hello Jan,
nice to see the development of PSPad going on. Thanks! As the author of the extension TypoScript extension "SweeTS" ( typo3.area42.de ) i get often the following wishes about PSPad:
- SFTP
- object oriented autocomplete (example if you write in html <img b you will get only the attributes that work with img tag and not thing like basefont etc.)
I agree with that wishes plus it would be nice getting 6 keyword groups including the possibilty of regular expression for building any kind of highlighing group based on the rule of a regular expression.
There are problems in the parser of the highlighter too, so
TypoScript code like that will working correct in the HL:
ACT.linkWrap
but starting with a order number like that:
1.ACT.linkWrap
will not highlight "ACT".
So there is often a problem in the highlighter with:
#Number.Keyword.keyword =
The first keyword after "#Number." will sometimes not be highlighted.
Karamba!
Bart.
Posted by: Bart | Date: 2008-03-27 18:53 | IP: IP Logged
Hi Jan,
another question: At the moment all clip files (*.def) located in the PSPad\context directory. When you cahnge them and update PSPad all your changes will overwritten.
Is it possible to have a "context" folder in the user data directory (c:\Documents and Settings\#Name\Appdata\PSpad)? So the *.def file of the PSPad\context folder and the c:\Documents and Settings\#Name\Appdata\PSpad folder will built together the available interactive clipse - mine and the standard clips of PSPad?
The same would be usefull for folders template, syntax, Script, plugins, convert and colors.
Karamba!
Bart.
Posted by: pspad | Date: 2008-03-27 19:00 | IP: IP Logged
PSPad is prepared for user paths for folders. I need to some time only to finish it.
I want to make user clip files - additions to standard clip files. But it is more complicated.
