You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2293) English
Posted by: pspad | Date: 2007-11-14 13:40 | IP: IP Logged
erema:pspad:I need confirmation if memory problems continue or not.PSPad still crashes in some cases, but now without "invalid pointer operation (etc)" alert - just closes.
I need more info, if it's possible to simulate it e.t.c.
Posted by: gurbao | Date: 2007-11-14 14:48 | IP: IP Logged
I am afraid the memo-style logwindow is still not working as I was expecting when e.g. capturing output from a powershell script.
Powershell output will generate "garbage" on both logwindow styles (memo and list).
Capturing SQL output works fine with both styles.
Could this have something to do with Unicode?
Using the 2281 build capture powershell output just fine.
Thanks,
Posted by: pspad | Date: 2007-11-14 16:35 | IP: IP Logged
Sorry, but I don't know what is your "garbage"
Some screenshot?
Posted by: gurbao | Date: 2007-11-14 19:45 | IP: IP Logged
Posted by: pspad | Date: 2007-11-14 20:06 | IP: IP Logged
You catch output or load it after program finish?
Posted by: gurbao | Date: 2007-11-14 20:29 | IP: IP Logged
Posted by: pspad | Date: 2007-11-15 05:15 | IP: IP Logged
OK. It means you can't capture output online, but you load LOG file created by your application
Posted by: erema | Date: 2007-11-15 07:33 | IP: IP Logged
pspad:I need more info, if it's possible to simulate it e.t.c.
1. new file or existing file - doesn't matter
2. word wrap is on
3. paste any long line (f.e. 300 signs) several times to get long-long line : if it's length is over 1000 (or so, maybe more maybe less) - pspad hangs or crashes or says "access violation" - but not always. sometimes all is ok.
inserting symbols somewhere inside long line often lead the same behavior
Posted by: alexandrul | Date: 2007-11-15 21:03 | IP: IP Logged
erema:1. new file or existing file - doesn't matter
2. word wrap is on
3. paste any long line .......
Same here, with a single line (9000 characters) in a file.
I've sent the file and the resulting logs in a mail to ''.phorum_html_encode('support@pspad.com').''
Edited 1 time(s). Last edit at 2007-11-15 21:03 by alexandrul.
Posted by: sophaly | Date: 2007-11-16 14:39 | IP: IP Logged
The separator just below the tab bar, and above the text area it's invisible.
Looks like there's a hole in PSPad and we can see through it.
This only happens in Windows XP desktop style. Classic style works fine.
Edited 1 time(s). Last edit at 2007-11-16 15:09 by sophaly.
