You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.3 (2269) English
Posted by: Stefan | Date: 2007-07-19 11:46 | IP: IP Logged
pspad:You can copy to clipboard text you want to use
as replace text and call dialog.
The you have prefilled both fields...
Yes, we understand this.
But the check box for this new settings
are under Settings > HTML
instead of Settings > Editor(part 3)
MrSpock:The new Search/Replace settings (clipboard/selected text)
are in the HTML tool section of the settings.
Is this intended?
Posted by: Stefan | Date: 2007-07-19 11:48 | IP: IP Logged
Jan, what means this?
Jan:Drag/Drop file into XHTML
- you can switch odd the CLASS attribute
in the Program settings / Direct edit
Stefan:Thank you Jan.Question:
Is this OK?
I see nothing about XHTML in "Direct edit" mentioned?Jan:Drag/Drop file into XHTML
in the Program settings / Direct edit1) I have downloaded: PSPad unicode 4.5.3 (2269) _16.07.2007
2) Unpack in a new folder.
3) Started PSPad two times.
4) Looked into "Direct edit"
But i see nothing about XHTML there mentioned?I see only this:
Quote:[Special settings]
LeftToPreviousLine=0
ContinueComment=1
OpenAllReadOnly=0
DontChangeFileAttribs=0
AutoDetectBinary=1
DragImgAlt=1
DragImgTitle=1
DragImgBorder=1
DragImgClass=1
TextClipsIfHLOff=0
CheckDocChanges=1
CtrScrollIfSelected=0
GutterClickInclLF=0
ExtraLineSpacing=1
OldMainIcon=0
HLOnUpToSize=500000
MultiHLOnUpToSize=200000
MaxRecentFiles=45
MaxRecentHistory=15
MainFileInPreview=0
F1HelpInEditor=1
ShowHint=1
Posted by: Stefan | Date: 2007-07-20 05:37 | IP: IP Logged
Jan didn't talk to me anymore???
I found that the misconception was by me.
I have translated
the english settings item "Tools"
to "HTML-Tools" in german,
because in the beginning there was
always HTML related items in there.
(Edit: the item call rs_tabHTMLTool, that's why i did so? )
So i should rename
the german translation to "Tools" too???
(Edit: yes, i have.)
Anyway this settings belong to "Program(Part)"
or "Editor(part)" better then to "Tools" ... isn't it?
Stefan:pspad:You can copy to clipboard text you want to use
The you have prefilled both fields...Yes, we understand this.
instead of Settings > Editor(part 3).
Is this intended?
Edited 1 time(s). Last edit at 2007-07-20 05:59 by Stefan.
Posted by: Deesy | Date: 2007-07-20 08:17 | IP: IP Logged
Hi.
Thanks for pspad.
is it possible to add colour for current column (as we have for current line in program settings - colors)?
Posted by: Joël | Date: 2007-07-20 19:29 | IP: IP Logged
Hi Jan,
Thanks for this new version.
The "problem" with syntax highlighting in LaTeX formulas is still there, for example $x^2$ is not highlighted and should be, but if preceded by a parenthesis like ($x^2$) it becomes highlighted... It behaves as if highlighting was defined as ($...$) instead of $...$. I would be happy if it could be fixed in the next version !
I had sometimes problems with version 2265, pspad crashing when I was simply typing text (maybe at the moment when an automatic backup was done). If it occurs again with 2269 I will try to isolate the error so that it could be reproduced and send you a report.
Have a nice weekend,
Joël
Posted by: Fraerok | Date: 2007-07-20 19:41 | IP: IP Logged
Hello!
I think, other editors have ineresting function:
at the finish of working function "Replace (Ctrl+H)" - in small popup-windows I can see how many replacing is maked. I click "Ok", and continuing working...
Can you make this feature in PSPad?
P.s. When we can see final version? =)
Posted by: pspad | Date: 2007-07-20 21:02 | IP: IP Logged
Fraerok:Hello!
at the finish of working function "Replace (Ctrl+H)" - in small popup-windows I can see how many replacing is maked. I click "Ok", and continuing working...Can you make this feature in PSPad?
Use Count button in the PSPad to know how much replacing you will do.
Final version will be soon
Posted by: whacker | Date: 2007-07-21 15:26 | IP: IP Logged
I hate to say this but when can we have the code block expand and collapse? I think this is a feature long overdue and should be given a very high priority over other features.
Posted by: holger | Date: 2007-07-21 19:11 | IP: IP Logged
whacker:I hate to say this but when can we have the code block expand and collapse? I think this is a feature long overdue and should be given a very high priority over other features.
I don't need codefolding when the Code-Explorer works correct. A function to find next upper/lower bound of current codeblock would be enough for me and could be made language indepentant, only using a few Language definitions.
PSPad knows already a lot of Languages, which one is "high priority"???
I think here is the bug forum and here comes some
(repeat list):
The new Version highlights labels for Progress.
Thanks Jan...
But it only highlight them if they are in the first or second Column.
Further a "do:" and a "repeat:" is also highlighted as Label.
Code-Explorer still cuts Procedure and Function Names at a "-".
Highlightning of multiline Strings is not correct:
(example)
d = "ab
c"
(Progress is able to include Files and give them Preprocessing-Parameters in Form:
{y/incl/y__prt00.if
&Firm = "Firm"
&ReferenzNr = "ReferenzNr"
&BufKopf = "Buffertable"
&Optional = "find Buffer2
/* even within a Comment: complete Text is referred to the Include as it is between Brackets */
of Buffertable"
where "&Optional" could be a unspecified optional search in the Include to manipulate the result.
Surely, if that findstatement would be longer this is unreadable within one line strings.
Preprocessorstatements are still not highlighted
begins with { ends with } (Multiline).
And as surely remarked once:
For Progress including Includes and commenting Comments is possible and not correct highlighted.
I don't know that much other Languages, but I need PSPad for Progress. Maybe it's easier to make a new Codeparser/Highlighter for it???
These are things of "high priority" for me and some of these things are surely the same in other languages.
Jan, please first finish your next stable release.
Please have a look what you can do for me after that.
I know that highlightning is not easy to handle with that much languages...
Edited 1 time(s). Last edit at 2007-07-21 19:13 by holger.
Posted by: whacker | Date: 2007-07-22 03:48 | IP: IP Logged
Code folding is not only for functions but also for very long and big IFs and SWITCHes.
Moreover, code folding will enable you to copy the whole function or whole block which have been folded into 2 lines rather than selecting N number of lines.
And furthermore, I would like to point out that the code explorer does not automatically update when there are changes in the code. Try writing a few lines in a function then click a different function in the code explorer and it will bring you to a different location in the code.
It may not be important to you but for me I find it very invaluable.
