You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2253) English
Posted by: pspad | Date: 2007-01-24 20:57 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.3 (2250)
News
After file close PSPad folder is set as the working directory. This prevent to lock file folder.
Removed recent files test during PSPad close process. This will speed up close process.
Added new File type ftAHK (AutoHotkey) for the Code parser
File tabs switch works always continuously from menu Window
New Program settings option - File tabs - double click closes file
Expanded VHDL code parser
Corrections
Next correction VMS and BS2000 PSPad FTP client
TyDi check was disabled in some cases
Sort with remove duplicities for ASCII
Perl highlighter
Script function inputText returns default text after Cancel button. Now it returns empty string
Cobol code explorer
Hangs with XML reformat
Ctrl+R in HTML preview calls Reopen in editor
Posted by: Peter Gomersall | Date: 2007-01-25 04:08 | IP: IP Logged
Jan,
Good job!
With ENG set as language there are 2 lines in Chesky on the Script menu (items 4 & 5):
priklad - otevreni souboru zFTP
priklad - odpodjeni FTP
Pete
Posted by: Mark.Ruffer | Date: 2007-01-25 06:40 | IP: IP Logged
Hi there,
also there is one untranslated line in the german menu. Submenu "Suchen" (Search) line 16 (the last one):
Smazat všechny zálotžky
PSPad is very good Editor!
Posted by: pspad | Date: 2007-01-25 07:38 | IP: IP Logged
Peter Gomersall:Jan,
Good job!
Pete
It isn't from the beta version.
Delete script file from .\Script\VBscript
Posted by: pspad | Date: 2007-01-25 07:41 | IP: IP Logged
Mark.Ruffer:Hi there,also there is one untranslated line in the german menu. Submenu "Suchen" (Search) line 16 (the last one):
Did you use current german language file from the CAB archive?
.\Lang\Deutsch.ini
I guess you unpack it without subdirectories, all into one folder
Posted by: Thomas | Date: 2007-01-25 07:55 | IP: IP Logged
Thanks for you ongoing work on this great editor.
I would like to see the 3 State-Checkboxes replaced with dropdown controls. It is very hard to understand (especially the "Auto Open New File After Start". It is nearly impossible to understand which state (on, off, "grey") means which setting. A drop down that says "Never, Always, Only if..." would be much more user friendly. The same goes for the File tab checkboxes. I find them very confusing. It would be slightly more helpful if the statusbar included the state in the description (On = Show always, Off = ...)
Please, please replace the three state checkboxes with dropdowns.
Posted by: Mahir | Date: 2007-01-25 08:25 | IP: IP Logged
what is the change about perl highliter ?
There is still an error in the highliter as you can see from a real code example below
if there is a new syntax file it is not in the cab.
regards,
Mahir
Posted by: mkukik | Date: 2007-01-25 11:09 | IP: IP Logged
Hi, is smart file tab switching working properly? I had difficulty in previous beta... and also in this realease.
Very strange behaviour. Sometimes I think I got the point, but sometimes it is switching randomly.
Posted by: Chris Pirillo | Date: 2007-01-25 12:10 | IP: IP Logged
1. New stable version of SynEdit available!!! sourceforge.net - you should integrate it for the next build. I hope it fixes the tab / window formatting issues.
2. PSPad works in Vista, but the window never remembers your toolbar placement settings in between sessions.
3. The About panel has a title of "O programu PSPad" in my English version.
Posted by: Fred | Date: 2007-01-25 15:26 | IP: IP Logged
@Chris Pirillo:
The old PSPad 4.3.3 uses SynEdit, the new 4.5 uses UniSynEdit (Unicode version).
