You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2253) English
Posted by: TRUSTAbyss | Date: 2007-01-27 22:10 | IP: IP Logged
I would like to have the option to Lock The Toolbars. I downloaded 4.5.2 and the Toolbars are locked. Let's try and keep it this way. Thank You.
Posted by: pspad | Date: 2007-01-27 23:33 | IP: IP Logged
paloy:Hello
With this version I have a problem : I can't input more than ONE tab at the start of each line, When I tape the second, the next line go up, I try a lot of configurations (real, smarts tabs )
In the 2250 all was ok.is it a bug ? or it's me
Thank you
[]Trim trailing spaces option
Posted by: Tim Milo | Date: 2007-01-28 15:08 | IP: IP Logged
Here are some issues, I found again in PsPad 2253 /
WinXPSP2:
(1)
The C/C++-Code Explorer shows under Includes the first "/"
character of a C-comment (the /**/ not the //) behind an
#include statement. I know this from 2243 or earlier), it
happens for .h and for .c files
(2)
The C/C++-Code Explorer shows function declarations with
multiple lines in the "Functions" category and not in the
"Prototypes" category, it happens for .h and for .c files
(3)
The C/C++-Code Explorer shows declarations of function
pointer types as "Prototypes" together with usual function
declarations .. is this desired?
(4)
There is a "C" letter partially visible right-side the icon
of the Code Explorer in 2253. What does it mean?
(5)
The hot keys for the selection type Shift+Ctrl+C/N/L are
still not shown in the menu like other keys ... one has to
read the manual first to get to know them.
(6)
The color selector window crashes always when switching
from any colors to "Named colors".
(7)
The file explorer wants to show tooltips .. their frames
stay empty without text and overpaint the explorer and
parts of the editor (until one stops moving the mouse)
Posted by: pspad | Date: 2007-01-28 16:55 | IP: IP Logged
1, 2, 3: I am not C programmer. Source sample please
4: Screenshot please
5: because it is editor command
6: I can't confirm. Maybe somebody can...
7: Can't confirm.
I guess many your problems coresponds to concrete PC configuration. Can you write it please?
Posted by: MrSpock | Date: 2007-01-28 20:22 | IP: IP Logged
(6) I can. Error log is on its way.
(4) I believe what Tim means is analog to the screenshot below:
(I know it's not the code explorer, but most likely it's the same thing.)
When the floating windows whose default position is on the right are docked on the left, part of the window title is displayed next to the icon, at least if there is a second row of tabs. So Tim's "C" is the first letter of "Code Explorer", I believe.
Posted by: Lolo | Date: 2007-01-29 09:11 | IP: IP Logged
Hello Jan,
There is a small bug in C text file.
Create a new C/C++ file.
Put the cursor between the two embraces and add the character *
void main()
Now, press enter.
The * is duplicate in the new line.
Only the character * seems to be a problem.
I hope you could correct this.
Have a nice day.
ps: I have made some test with other languages and there is the same problem.
Edited 1 time(s). Last edit at 2007-01-29 09:12 by Lolo.
Posted by: pspad | Date: 2007-01-29 09:54 | IP: IP Logged
Lolo:Now, press enter.
Program settings / DIrect edit
change: ContinuComment=0
Posted by: Lolo | Date: 2007-01-29 10:08 | IP: IP Logged
OK, thanks.
But do you think it is normal?
The comment in Visual Basic file is '
If I press ' then enter, the ' is not duplicated
Only the * is duplicated.
Is it a bug?
Posted by: pspad | Date: 2007-01-29 10:38 | IP: IP Logged
This is a documentation comment in some languages
{ starts it, then lines with * follow and } finishes it.
Edited 2 time(s). Last edit at 2007-01-29 10:39 by pspad.
Posted by: Lolo | Date: 2007-01-29 10:49 | IP: IP Logged
OK, you are the boss.
And the boss is always right
Have a nice day.
