You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2211) English
Posted by: Joe Belmaati | Date: 2006-05-11 21:28 | IP: IP Logged
Not sure whether it is appropriate to bring up once again - if not, then apologies:
The ALT problem still exists (at least on my XP Pro SP2 machine), i.e. bookmarks with ALT+Left don't work.
Sincerely,
Joe Belmaati
Copenhagen Denmark
Posted by: Jume | Date: 2006-05-11 23:39 | IP: IP Logged
Joe Belmaati:Not sure whether it is appropriate to bring up once again - if not, then apologies:
someone asked this in other beta version forum, same as i answered before:
it happened to me also some betas ago (entire monthS ago), a bit bad since i have my own keys for some things, but a way to solve it is to reset to default keymap in config, another would be deleting the keymap file, though i did not need it, a pspad restart in the first method should be a correct thing to do...
it maybe is some incompatibility in either a shortcut name or even in something like codepage, i dont know... good luck, mine work fine again ever since, of course, i needed to reconfig my shortcuts
Posted by: Tiger | Date: 2006-05-12 05:04 | IP: IP Logged
What about searching in Files, written in CP866? This doesn't work, though simple search in current file works pretty...
Posted by: Joe Belmaati | Date: 2006-05-12 08:20 | IP: IP Logged
Jume:Joe Belmaati:Not sure whether it is appropriate to bring up once again - if not, then apologies:
The ALT problem still exists (at least on my XP Pro SP2 machine), i.e. bookmarks with ALT+Left don't work.someone asked this in other beta version forum, same as i answered before:
Hi, I actually tried all of those including deleting keymap.ini
Posted by: Bart | Date: 2006-05-12 18:46 | IP: IP Logged
It would cool if all Icons where localized in the BMP files of the skin. A thing i didn't understand is why the code explorer has its own paste, refresh and synchronize icons. We have these functions at the file explorer too and they use icons of the skin BMP.
My favorite features i'm missing all the time are:
- Extended replace like homesite has
web.bentley.edu
- STP-Support
- The compress and restructure buttons in the toolbar would work for CSS too
Anyway i love PSPAD!
PS: I'm working on a higjlighter for TypoScript (CMS Typo3) and on a icon theme based on the Tango-Project icons.
Posted by: mdes | Date: 2006-05-12 21:44 | IP: IP Logged
Shift+Tab a selected text gives:
List index out of bounds (1).
Exception class:
Exception address: 00421769
Stack list, generated 12/05/2006 23:39:10
Edit by mod:
By an advice of the author!
Thanks for the report, but please
do not post such "Access violation" messages into the forum,
but post only an hint that you have this error
and send the error log itself to the Author Jan by email! (sup p ort - a't - pspad - c0m)
Thanks for the report and your comprehension.
The mod.
Program : C:\Program Files\PSPad\PSPad.exe 4.5.2 (2211)
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 2"
Processor: AMD, AMD Athlon(tm) 64 Processor 3500+, 2220 MHz MMX
Display : 1280x1024 pixels, 32 bpp
Active Controls Hierarchy:
Edited 1 time(s). Last edit at 2006-05-14 13:14 by Stefan.
Posted by: McBain | Date: 2006-05-14 15:45 | IP: IP Logged
there is a bracket-highlighting bug.
Copy this to a php-document:
<?php
if (1==!) {
And select just the first {-bracket (last sign in the IF-line).
->The following }-bracket gets highlighted.
Now set the cursor to "if" -> the last bracket is still highlighted.
Greetings,
McBain
Posted by: MrSpock | Date: 2006-05-14 15:51 | IP: IP Logged
McBain:Hi,there is a bracket-highlighting bug.
<?php
if (1==!) {
?>And select just the first {-bracket (last sign in the IF-line).
Now set the cursor to "if" -> the last bracket is still highlighted.Greetings,
McBain
Can't confirm. I tried it exactly as you said, but for me it works.
Posted by: McBain | Date: 2006-05-14 19:27 | IP: IP Logged
MrSpock:Can't confirm. I tried it exactly as you said, but for me it works.
Strange...
The cursor is between the I and the F (I|F).
So the }-bracket should actually NOT be highlighted anymore.
Just in case it's important:
Win XP Home Sp1
Posted by: MrSpock | Date: 2006-05-14 19:37 | IP: IP Logged
I placed the cursor almost everywhere, including between "i" and "f", for me it just doesn't happen.
